Username Post: Troublesome P2135 Code        (Topic#344796)
harbison
Reg: 05-18-17
05-18-17 07:14 AM - Post#2691759
I've been dealing with this code off and on for nearly two years. I've changed TPS Sensor several times, changed MAF sensor, cleaned Throttle Body, replaced TPS Sensor pigtail (broken clip), Reprogrammed ECM at dealership. Changed TPS Sensor two weeks ago (AC Delco) and followed the Technical Service Bulletin to the letter. Last night experienced "Reduced Engine Power, Stabilitrack Off, and Code P2135. Most people seem to replace the TPS Sensor and never have another problem. Any suggestions?
05-18-17 02:25 PM - Post#2691781
    In response to harbison
Welcome to AF, no mention of year and engine. Anyway if this is drive by wire, there a tps on the accelerator pedal and the throttle body.
harbison
Reg: 05-18-17
05-19-17 05:09 AM - Post#2691864
Sorry about that.
2009 GMC Yukon XL
5.3L, 2WD, 198,000 miles
05-19-17 12:14 PM - Post#2691915
Ok, you are drive by wire, tps on gas pedal and throttle body.
Execution time: 0.241 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:53 PM
