Username Post: 1985 c10 350 how much HP        (Topic#344753)
coltin87
Reg: 05-15-17
05-15-17 12:54 PM - Post#2691432
so i am trying to figure out how much hp my 350 makes.
it is a stock 350 right out of the machine shop.
it has a melling 22200 cam
cam specs
290 .298 .447 110 1.5
it has stock heads with z28 springs
it has a hei distributer a performer edelbrock intake and a 1406 600 cfm edelbrock carb.it has long tube headers. it is hooked up to a 700r4.
05-20-17 11:41 AM - Post#2692046
    In response to coltin87
You are presently in the 1984-86 full size passenger car forum. I have asked the moderator to move this thread to the 1973-87 truck forum, where you will likely receive more replies.
grumpyvette
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
08-27-17 09:21 AM - Post#2705756
your probably in the 240 hp-270 hp range with the combo as stated , obviously theres modifications that can be done to increase that power level but keep in mind the drive train gearing and your brakes are also systems that may need upgrades as well.
Execution time: 0.345 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:15 PM
