Join the Community today
Username Post: alternate hardener for ppg dxc61        (Topic#344642)
delaney
Reg: 10-24-04
05-10-17 10:46 AM - Post#2690595
looking for an alternate hardener to use in the k36 primer converting it to a sealer primer.
The PPG k36 primer uses the PPG K201 hardener for use as a high-build primer coating. In addition to be used as a primer it can be used as a "sealer" by either using the ppg hardener DCX61 or a DCX8 hardener in lieu of the k201 hardener when using the k36 and the clear DCU2021 to form it as being a sealer. Well this DCX61 or DCX8 cost over a $100 which is way too much for me. Looking for a alternate hardener to use.
Have others use the K36 for a sealer and used an alternate hardener with positive results. Thanks
Execution time: 0.236 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:06 AM
