Username Post: Is this normal?        (Topic#344535)
carolinakid
carolinakid
Loc: Sanford NC
Reg: 08-27-03
05-06-17 08:53 AM - Post#2689838
Donny,
A few times when turning off my 56 I've accidentally turned the key counterclockwise to the LOCK position on the ignition switch. The engine has continued to run. Is this normal? Thanks
carolinakid
carolinakid
Loc: Sanford NC
Reg: 08-27-03
05-06-17 10:22 AM - Post#2689846
    In response to carolinakid
Donny, I do have a Power 8 Plus Fuse Panel
aawtech
Loc: Bellmawr, NJ
Reg: 09-11-06
05-06-17 12:02 PM - Post#2689860
You have to turn it to OFF first, then lock, especially if it is a replacement switch
Donny
carolinakid
carolinakid
Loc: Sanford NC
Reg: 08-27-03
05-12-17 11:48 AM - Post#2690907
    In response to aawtech
Donny,
Is this an issue with replacement switches? Have checked Ignition Switch and it is wired correctly. When I turn the switch to off and then to lock it works as designed and engine shuts off.
aawtech
Loc: Bellmawr, NJ
Reg: 09-11-06
05-14-17 11:16 AM - Post#2691231
  • carolinakid Said:
Donny,
Not 100% sure, just know that I have run into the same problem myself. Could have something to do with the fact that there is no true accessory position, and as such, when the rotor in the alternator is spinning and backfeeding 12 volts to the switch, won't allow the car to shut off.
Edited by aawtech on 05-14-17 11:19 AM. Reason for edit: No reason given.
carolinakid
carolinakid
Loc: Sanford NC
Reg: 08-27-03
05-19-17 07:44 PM - Post#2691972
Donny, Thanks once again, Carolinakid
Execution time: 0.504 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:13 AM
