Username Post: WTB Borg Warner Overdrive R10 Governor Gear        (Topic#344185)
mark50
Loc: SF, CA
Reg: 05-10-04
04-21-17 08:15 AM - Post#2687594
I have completely rebuilt my 3 speed transmission with Borg Warner R10 overdrive and realized it's missing the Governor Gear. Overdrive won't work correctly without, so the search is on. Do you have a spare? Even if its the whole Governor assembly?
Thanks in advance
Edited by mark50 on 04-21-17 11:18 AM. Reason for edit: No reason given.
04-21-17 09:28 AM - Post#2687603
    In response to mark50
You are presently in the 1949-54 classified ads forum. In case you are not already aware of this, GM did not offer an OD transmission until 1955. To further complicate matters, GM used different governors over the years which are not physically interchangeable.
Please post the letter appearing after "R10" on your OD housing. Once you do that, I will ask the moderator to move this thread to the most appropriate forum for your particular unit.
mark50
Loc: SF, CA
Reg: 05-10-04
04-21-17 11:18 AM - Post#2687614
Thanks Ray, done!
04-23-17 12:40 PM - Post#2687940
I found your duplicate posts in both the 55-57 and 58-60 classified forums and have asked the moderator to delete this thread.
Execution time: 0.19 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:55 AM
