Username Post: Dumb Horn Question        (Topic#344162)
Bill K.b
Loc: upstate NY
Reg: 10-24-05
04-19-17 11:45 PM - Post#2687411
My '02 van the horn worked fine until it got super cold out, then it just quit when it was regularly below freezing for a while. Nothing when you hit the button. One time it did work going down the road, but quit within a few minutes. Well, it had passed inspection so I figured when it warms up I'll have to figure out what's not working and change it.
I happened to check it again once it finally got somewhat warm and it works again.
What's going on here? The horns themselves, maybe have water in them (they're down in on the inner fender below the master cylinder), or the relay has issues? Maybe there's even no way to check until it gets cold again.
Those who can, do. Those who can't, criticize it on the internet.
1988 G20 van 5.7L - driver.
1993 3500 dually 5.7L NV4500 - tow truck
1991 G20 van - parts truck
Plus cars for swap and sale
&yes, I once tried a frame swap on a 51 Chevy.
McLeod
McLeod
Loc: North Carolina
Reg: 01-10-05
04-20-17 04:14 AM - Post#2687429
    In response to Bill K.b
...likely just build up of corrosion on contacts. You can pull it apart and clean them...or, just really push/hit the horn hard & it'll blow. (Mine didn't blow for years & I dreaded having the inspection, but the inspection station always "made" it blow by pushing super hard. Then, I finally got a "roundtoit" & cleaned the contacts.) Mc
McLeod -- 1999 Tahoe LT, '03 2500HD Ext. Cab.
JaVeRo
Loc: East Texas
Reg: 02-02-06
04-21-17 06:36 AM - Post#2687585
    In response to McLeod
Mine will work in some positions and not in other positions. If I am driving and want to honk the horn, I have to push the button and then jerk the steering wheel to the right a little.
Not recommended for high speed traffic
James
2003 S10 Blazer 4wd (wife's)
2001 S10 Crew Cab (wife's mail truck)
1996 K1500 (mine)
1979 GMC 3/4 ton 2wd 4spd with a "Gilley's" bumper sticker, my first brand new truck.
2006 K1500 Company Truck
2006 K2500 NV4500 4.10's
Bill K.b
Loc: upstate NY
Reg: 10-24-05
04-25-17 01:32 AM - Post#2688160
    In response to JaVeRo
If it was the horn button contact in the steering wheel/column, I have to presume after driving it for two hours with the heat on it would be warm enough to work. But that doesn't seem to matter.
Edited by Bill K.b on 04-25-17 01:32 AM. Reason for edit: No reason given.
Algoma56
Reg: 03-14-05
04-28-17 07:01 PM - Post#2688781
Slightly off topic, but I had a Camaro once that you could barely hear the horn. The front clip had been pieced together, and the previous owner had installed the horn facing up. It was full of water! Check yours, maybe it's wet, and frozen.
05-02-17 05:53 PM - Post#2689362
    In response to Algoma56
I never delved into it, but my '99 Silverado did the same thing. When it got really cold the horn wouldn't work, but it only did it a couple of winters and now works regularly. I am a fairly frequent horn user, so I know when it is or isn't working.
Bill K.b
Loc: upstate NY
Reg: 10-24-05
12-27-17 01:51 PM - Post#2719127
    In response to wagonman100
No, it was the horns going bad; pressing with the van shut off I can hear the relay click and no beep.
These horns have two wires going to them, is one a ground? I'm replacing them with a Harbor Freight 2-note air horn and it would be nice to know how this circuit works.
Bill K.b
Loc: upstate NY
Reg: 10-24-05
12-29-17 04:47 PM - Post#2719364
Black wire ground, green wire 12v+. Up and working despite the cold.
Execution time: 0.296 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:37 PM
