Username Post: Need to remove fuel guage sender        (Topic#344127)
carolinakid
carolinakid
Loc: Sanford NC
Reg: 08-27-03
04-18-17 02:44 PM - Post#2687180
My fuel gauge sender has developed a leak by the fitting. Any tips on changing this out. Is it easier to drop the tank? I don't have a lift. Are the senders all the same? Rubber or Cork? Thanks
Edited by carolinakid on 04-18-17 02:46 PM. Reason for edit: No reason given.
5Larry7
5Larry7
Loc: Dallas, TX
Reg: 05-17-04
04-18-17 08:08 PM - Post#2687258
    In response to carolinakid
Tri Five fuel senders can be removed without removing the tank. The fuel level should be half full or less though. The sender and fuel outlet are all in one unit located at the front of the tank, accessible from under the car.
carolinakid
carolinakid
Loc: Sanford NC
Reg: 08-27-03
04-19-17 01:28 AM - Post#2687273
    In response to 5Larry7
Thanks for the info. I noticed Danchuk sells a "Best" and a "Good" Sending Unit. Do you know what the difference is?
57tim
57tim
Loc: Cameron, Wi, USA
Reg: 11-09-01
04-20-17 07:48 AM - Post#2687456
I would always go for best on a item like that. Get new screws with copper washers and composite gasket.
57 Bel Air 2dr Ht
327 700r4
mike56
mike56
Loc: Kansas
Reg: 08-26-08
04-20-17 07:55 PM - Post#2687539
Ditto on the copper washers and new screws, the washers help seal leaks coming up the threads and out under the screw heads.
Big T
"12th Year" Silver Supporting Membe
Big T
Loc: Simi Valley CA
Reg: 04-14-06
04-21-17 01:40 AM - Post#2687562
    In response to mike56
The better gasket IMO is rubber. Others favor cork. I believe my unit came with a cork gasket. They sell the rubber gasket as a separate item.
Tom
Tom
55 4 door BelAir
Bad56Sedan
Bad56Sedan
Loc: Pasadena, Texas
Reg: 04-29-04
04-28-17 07:58 PM - Post#2688787
If it was me I would add the shunt wire to the new sender
VC56S 2 door Sedan, 38 Years
carolinakid
carolinakid
Loc: Sanford NC
Reg: 08-27-03
05-02-17 07:15 AM - Post#2689297
    In response to Bad56Sedan
Bought new sender. It was easier for me to just remove the tank to replace sender. Danchuk actually has instructions for changing out senders. Old sender had in addition to a crack at fitting there were several cracks in float.
Plan on saving old sender as a spare. Ohmed out correctly. Went to repair loose fitting by reheating solder without much luck. Cleaned pipe and fitting and used JB Weld. Haven't a clue if JB Weld will holdup. Cross that bridge if new one ever goes bad. Is a shunt the same as a ground?
Thanks to all for responding
pauldian
Loc: seligman,arizona
Reg: 05-14-09
05-02-17 07:40 AM - Post#2689298
a shunt (simplified) is a small wire that takes power from a large wire for what ever it is needed for.
Lee T
Reg: 07-05-12
05-02-17 02:02 PM - Post#2689332
    In response to Big T
Cork is not compatible with ethanol, neoprene rubber is compatible.
05-02-17 04:57 PM - Post#2689353
    In response to Lee T
The "best" Danchuk sender comes with a cork/rubber gasket and a better float. That's the one you want. The other one comes with an inferior Chinese brass float and a rubber gasket that leaks.
Most guys have the best luck with a cork/rubber gasket - even if cork is incompatible with ethanol. Many complaints here and on other forums about rubber gaskets leaking.
As said, you need to get the Danchuk sealing washers for the screws. Also use some non-hardening sealer on the screw threads. Permatex #2 works well.
The bolt hole pattern in the sender/gasket/tank is not evenly spaced. Make sure the hole pattern on the gasket lines up correctly. On some gaskets there is a notch or tab on the outside, line it up with the "dot" on the sender.
gbafus
Loc: Camas, WA
Reg: 07-30-06
05-09-17 10:09 PM - Post#2690529
The fuel pickup tube that passes thru the sender is soldered in place. A small torch is best to heat the joint sufficiently to seal a crack. You will need a coil of acid core solder to make a leak proof repair. Obviously, DO NOT attempt this with the sender anywhere NEAR the tank!
It may make it easier to leave the tank straps slightly loose when lining everything up. I did this job on a '55, 57 may be different. There must be NO strain on the pickup tube to get threads started on the fuel line. If so, you WILL crack that solder joint. I did mine in 1993....so my memory may be a bit....fuzzy
George
Chevrolets previously owned:
1947 Fleetline Aerosedan
1955 Bel-Air 4 Door Sedan
1958 Biscayne 2 Door Sedan
1977 Monte Carlo
Currently own:
1957 Bel Air Sport Coupe
Bad56Sedan
Bad56Sedan
Reg: 04-29-04
05-23-17 05:57 PM - Post#2692545
The shunt wire I'm speaking of removes the inconsistency of the electrical contact between the float wire and the resistor case.
This simple addition should be done any time the gas level sending unit is removed/replaced.
You will be surprised how steady the gas level gauge acts.
Just a suggestion.
57chevyeddie
Loc: Ga.
Reg: 09-15-04
05-25-17 08:46 PM - Post#2692946
how do you attach the shunt on the resistor housing? I guess this will take the place of the metal strip from the wire connector to the housing. My new sensor is braded at both ends and loose. I replaced it today with my 60 year old original sensor.
Bad56Sedan
Bad56Sedan
Reg: 04-29-04
05-26-17 05:40 PM - Post#2693067
    In response to 57chevyeddie
The shunt wire is attached to the float wire and the suction tube, you can soldier it on. It is the red line in the pic.
Attachment: 29-01.jpg (13.27 KB) 16 View(s)
madasell
madasell
Loc: Great North-Wet, Orygun
Reg: 04-21-03
05-30-17 12:12 PM - Post#2693500
So, the shunt is a wire to tie the tank ground to the float arm, to add an additional ground connection to the sometimes flaky arm contact between the arm and the sender case? Did you use copper braided wire shunt? This sounds like a good plan.
Do these fins make my rear end look big?
Bad56Sedan
Bad56Sedan
Reg: 04-29-04
05-30-17 08:24 PM - Post#2693608
    In response to madasell
The wire I used was a lead wire for a volt meter with the plastic covering removed.
madasell
madasell
Reg: 04-21-03
05-31-17 12:51 PM - Post#2693704
Great idea, thanks!
Execution time: 1.615 seconds.   Total Queries: 18   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:08 AM
