Username Post: ZZ4 intakes        (Topic#344118)
PHROG
Loc: Amarillo, Texas
Reg: 02-14-17
04-18-17 09:35 AM - Post#2687148
I would be interested in a fact based opinion on preference for ZZ4 intake between as delivered versus original Edelbrock Performer. My prime consideration is torque/fuel mileage below 75mph cruising speed @2500rpm. This will be in a 34 Chevy @3100lb.
THANX
34 Master 5 wdo, 64 Corvette roadster, 64 4x4 Suburban, 72 C10 Highlander,
IgnitionMan
Reg: 04-15-05
04-18-17 10:07 AM - Post#2687152
    In response to PHROG
NO comparison, keep the ZZ manifold.
grumpyvette
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
04-18-17 04:20 PM - Post#2687217
    In response to IgnitionMan
without knowing the cam,lift & duration and LSA,cylinder head flow rate, engine displacement and compression, and the specs on the headers , and the exhaust system back pressure at 3000 rpm, being used you can,t reasonably predict the engines potential power curve, with out the rear gear ratio, tire diameter and transmission gearing your can,t predict the engines potential, useful torque in the intended rpm range. .
and if your only really concerned with the torque curve below 3000 rpm I doubt there's much to be gained with an intake manifold swap, between those two intakes
Edited by grumpyvette on 04-18-17 04:23 PM. Reason for edit: No reason given.
IgnitionMan
Reg: 04-15-05
04-18-17 05:03 PM - Post#2687227
My response was based on the intake being bolted to a ZZ3/ZZ4 engine. "ZZ4 intake, as delivered".
1983G20Van
Loc: Bedford, Texas, USA
Reg: 11-13-02
04-20-17 12:07 PM - Post#2687488
I have had very good luck with the Performer RPM spreadbore intake and a Q-Jet. My old 1983 G20 van knocked on 20 mpg more than once with a 350 HP 350 backed to a 700R4 and 3.08s. 1,700 rpm @ 70 mph. I later put a 454 TBI unit on the engine and regularly pulled down 22 mpg highway in lean cruise at 16.5:1 afr.
04-20-17 04:38 PM - Post#2687518
    In response to 1983G20Van
Nobody pointed out why not to change to the Performer from the ZZ4 manifold.
My guess is that the Performer is not better or worse, it's essentially the same. So you run either one, or the one you have.
Maybe someone can verify this, as I've never owned a ZZ4 manifold.
I do know that while a Performer RPM manifold should produce more peak power at the expense of low end compared to a Performer, the real world difference is pretty small.
65_Impala
Reg: 12-29-02
04-21-17 08:55 AM - Post#2687598
    In response to Rick_L
The ZZ4 seems to fall between the Performer and the Performer RPM.
Data I have seen points to the Performer RPM working not losing any low end power compared the Performer, at least not down to where you'd expect to actually run the engine in practice.
1983G20Van
Reg: 11-13-02
04-21-17 08:59 AM - Post#2687599
    In response to 65_Impala
I ran that induction setup on the stock 305 when I put a small 204/214 rv cam into it for over a year. It pulled hills better than it did stock with less downshifting. The stock intake and cam should have made more torque on paper but in the real world it did not.
With the Q-Jet the performer rpm had very sharp part-throttle response and did not require alot of throttle to get rolling. I had Thorley Tr-Y headers and 2 1/4" dual exhaust with a X-pipe on that as well.
CarCraft tested the performer and performer rpm on a similar LG4 305 back in the day and found that the RPM made more torque and hp. I wanted the power in the heavy G20 van and used that as my basis to run that induction setup.
Edited by 1983G20Van on 04-21-17 09:06 AM. Reason for edit: No reason given.
1983G20Van
Reg: 11-13-02
04-21-17 09:02 AM - Post#2687600
Double post
Edited by 1983G20Van on 04-21-17 09:02 AM. Reason for edit: No reason given.
IgnitionMan
Reg: 04-15-05
04-21-17 09:14 AM - Post#2687601
The biggest problem with the ZZ engines is, NOT the intake manifold, it is the really bad ignition setup as far as curves, namely, using ported vacuum for the vacuum advance, and allowing it to provide way too many degrees, along with making the mechanical curve need to be slowed way down, to allow the ported V/A.
There is a simple procedure to rectify that, proven to work by one heck of a lot of people on their ZZ, and other Chevrolet engines, it is free, available from:
gmvacuumadvancemodificati ons@gmail.com
Then, a SENSIBLE 600 cfm Holley carb, good combo.
1983G20Van
Reg: 11-13-02
04-21-17 09:55 AM - Post#2687604
SMI Q-Jet is the only carb to run for fuel economy. No reason to choke it down with a 600 cfm carb when the Q-Jet can deliver better economy and flow up to 795 cfm on demand.
56sedandelivery
56sedandelivery
Loc: Everett, Wa.
Reg: 02-26-08
04-21-17 03:22 PM - Post#2687648
Cost VS Cost. IF there were any kind of improvement, how long would it take in manifold/gasket/labor terms ($$$) to justify the change? I'd keep what you have already, and it should have a Bowtie on it to show support, of the Bowtie. Any time a magazine does "tests", I have to wonder just how un-biased they really are. Got to be some $$$ exchanging hands somewhere, even if it's in ads, placed by the maker of the product being tested. $$$ is what makes the world go round', and everything possible. IF you had a choice of the 2 manifolds, sitting new in front of you, most guys would probably pick the Edelbrock, no matter what the magazine reports say. JMO.
I am Butch/56sedandelivery.
LUVmachine
Loc: Redding Ca
Reg: 10-02-14
04-22-17 07:55 AM - Post#2687722
I would agree with that minus the last part about picking the Edelbrock. That's just a personal preference though.
71 Chevelle BBC powered
2010 GMC Sierra crew cab 4X4
Senior Chevytalk Moderator
04-23-17 03:59 AM - Post#2687862
    In response to LUVmachine
Unless you want replace it for looks, the ZZ4 intake is fine. I swapped a stock on one for looks. Afterwards, I had to customize a throttle bracket for cruise and TV cables. If the engine is out, remove the bolts one at a time. The intake bolts will leak oil. I used Form-a-gasket aircraft sealer to reduce oil seepage. If you take the intake off, a thicker and factory RTV bead will seal the front and rear block lips. The oil pan will leak around the corners. A little RTV or form a gasket will stop oil leaks. I used sealer on both gasket sides. After 10+ years, oil leaks are minimal or none.
Jim McCall
"7th Year" Platinum Supporting Member
Jim McCall
Loc: Billings Mt
Reg: 02-18-10
04-24-17 07:20 AM - Post#2688032
Below is a photo of the ZZ4 in my 33 Ford. The intake is a Edelbrock endurashine manifold. The engine with this intake has Great performance. I have to admit I'm into shiny engines in my cars.
Jim McCall
33 Ford 3-window
34 Ford Roadster
51 Belair
55 Belair
55 Belair
57 Buick
68 Camaro SS427
69 Camaro Z/11
71 Camaro Z/28
04-24-17 07:45 AM - Post#2688036
    In response to Jim McCall
Attachment: Picture_039.jpg (127.66 KB) 7 View(s)
Might as well show off mine when it was cleanly installed.
Jim McCall
Jim McCall
Loc: Billings Mt
Reg: 02-18-10
04-24-17 08:37 AM - Post#2688044
Nice
33 Ford 3-window
34 Ford Roadster
51 Belair
55 Belair
55 Belair
57 Buick
68 Camaro SS427
69 Camaro Z/11
71 Camaro Z/28
1983G20Van
Reg: 11-13-02
04-24-17 03:04 PM - Post#2688092
[IMG]http://i243.photobucket.com/albums/ff172/Fast355_ album/6341720093_large_zp srjxazty7.jpeg[/IMG]
This was mine years ago with my own clone of a 310 hp TBI marine engine. GM built them from 1996-1998ish with the ZZ4/L98 heads and the 395' Marine cam. Ran a performer rpm like manifold and a 2" bore TBI unit. Mine had a 46mm TBI unit on a Holley Projection adapter on an RPM. Was not pretty but had no problem pushing around my old G20 van.
PHROG
Reg: 02-14-17
04-25-17 07:32 AM - Post#2688191
First I would like to thank everyone that replied. Now I think a little more info might be in order. My ZZ4 is one I pulled from a El Camino passing thru my hands about 10 years ago w/approx. 2200 miles. It is presently sitting on my engine stand being resealed to be on the safe side prior to install. I have a new Performer on the shelf, so cost is not a consideration. I will be using a Q-Jet that is presently on the current engine in the car which is a stock 71 pu engine that has reached an oil consumption level of 400 miles per qt. The Q-Jet will be setup again w/an exhaust gas analyzer. I also will be using Doug's Tri-y headers. The main reason for my consideration of the Performer is the elimination of the EGR & Choke stove block-offs on the ZZ4 intake, but don't want to lose performance,as stated, due to looks.
THANX
04-25-17 07:46 AM - Post#2688192
EGR and choke removal were why I swapped intakes. The smaller L98 valves limit its HP. If larger valves were installed, the ZZ4 can go up to 400+ HP.
Another weakness are the rocker arm nuts. Since the engine is out, install short poly locks. Go here to see them installed: http://www.chevytalk.org/fusionbb/showtopic.php?ti...
With a zero lash requirement, it's easier with the engine out.
Execution time: 0.352 seconds.   Total Queries: 18   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:49 PM
