Username Post: Has anyone had something stolen off their truck at a shop?        (Topic#344108)
Eric_Gary132
Loc: northern California
Reg: 01-27-17
04-17-17 07:09 PM - Post#2687068
I could've sworn my truck had the flywheel cover on the flywheel.
A couple of days after I took it back from the repair shop, I noticed the flywheel cover was missing and the flywheel was exposed and could see it spinning.
I'm not sure if someone there stole it or it was like that when I bought it.
Has anyone experienced theft at classic repair shops?
Needles
sidworks
Loc: Sidney, B.C.
Reg: 12-03-05
04-17-17 07:56 PM - Post#2687074
    In response to Eric_Gary132
if you do not know whether or not that your truck had tye cover when you bought it, how can you say that someone stole it. it could have been left off 5 years ago
ron
http://www.sawmillcreek.org/showthread.php?208929-...
http://www.sawmillcreek.org/showthread.php?220902-...
http://forum.woodenboat.com/showthread.php?156542-...
GreatNorthWoods
GreatNorthWoods
Reg: 03-31-02
04-18-17 04:27 AM - Post#2687105
That would be a very odd object of theft. Replacement dust covers are easy to find and inexpensive. There are even universal ones that fit multiple applications. Perhaps it was not bolted on tight and the screws vibrated out or you could have run over something and it was ripped off but I highly doubt it was stolen. What kind of work did you have done? Perhaps it had to be removed and someone forgot to put it back on???
Vern
1953 Chevy Belair Sport Coupe - 350 Crate Engine,700-R4, Vintage Air, EZ Wire, Ididit column, Cruise/Tilt, 4-Wheel Disc Brakes, Nova 10-bolt, Chassis engineering front suspension.
Eric_Gary132
Reg: 01-27-17
04-18-17 04:51 AM - Post#2687109
I had the shop adjust the clutch
Needles
daustin
Loc: Woodstock, Ga
Reg: 12-03-08
04-18-17 09:25 AM - Post#2687147
There's no reason to remove it to adjust the clutch.
1957 210 2d Post
1961 Bubbletop Impala
1965 Buick LeSabre
1968 327 Camaro
1968 427 COPO Corvette
1984 Monte Carlo SS
1969 RS Camaro
1969 GTO
1976 Camaro
1993 Silverado 3500 Dually 6.5TD
1993 GMC 1500
1994 9C1 Caprice
1997 Silverado 1500
04-20-17 01:21 PM - Post#2687498
    In response to daustin
As you correctly say, there is no need to remove the cover when doing a clutch adjustment. However, when I adjust mine I always remove the cover so I can see the edge of the disc to get an idea of how much thickness is left.
WagonCrazy
WagonCrazy
Reg: 06-07-05
04-21-17 05:55 AM - Post#2687587
Did you call the shop and ask if they forgot to put it back on?
Eric_Gary132
Reg: 01-27-17
04-21-17 10:32 AM - Post#2687609
    In response to WagonCrazy
Yes, called the shop and the owner went looking for it. They apparently couldn't find any flywheel cover in their garage.
Needles
Eric_Gary132
Reg: 01-27-17
04-21-17 10:34 AM - Post#2687610
The name of the shop is "Rods R us". Located in Sacramento, California
If anyone has been there multiple times and has info about this shop I'd appreciate it.
Needles
Edited by Eric132 on 04-21-17 10:37 AM. Reason for edit: No reason given.
hilandr451
hilandr451
Loc: Anna Texas
Reg: 01-02-02
04-26-17 09:53 AM - Post#2688341
I'm not saying this is what happened to your truck, but I know sometimes stuff doesn't always get put back on - they were either broken, a pain in the butt or they just plain missed it until they handed he keys to the service writer (flywheel covers, starter heat shields, plug wire brackets etc.) I've worked with mechanics who have done this and then hidden the evidence so they wouldn't get in trouble.
-The Hilander.
Silver 2017 Silverado 1500 double cab 2WD 5.3L
"Rattle can primer red" 1966 C20 Custom Camper 5.7L, 700 R4 trans 410 diff. front disc, p/s
Project Pics
Execution time: 0.156 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:17 AM
