Username Post: 1952 Chevy Deluxe - brake problems        (Topic#344055)
classicguy
Gold Supporting Member
Loc: Palm Springs, California
Reg: 04-15-17
04-15-17 03:40 PM - Post#2686778
the brakes on my car are like pushing on a brick wall! I can barely stop the car sometimes. I've had the mechanic flush all the lines, re-build the master cylinder, bleed the lines and put on new shoes - nothing helps! Anyone have any ideas of what to do next to make these brakes safe and not take so much effort to stop the car?
Bel Air kiwi
Bel Air kiwi
Reg: 04-24-14
04-21-17 02:05 AM - Post#2687564
    In response to classicguy
Hi Classic guy, If the car is an original all drum car then you can improve that two ways. One is to add a power booster which will lift the assist by a factor of about 1.2 to 1.4, the other is to not use hard shoe lining material but get soft linings. They are not as common as they wear much more quickly and are usually a custom reline of your shoes, but work much better. Does your car have Huck or bendix brakes?
Cheers Kiwi
2blu52
2blu52
Reg: 03-12-02
05-19-17 04:51 AM - Post#2691868
Often times when brakes are are replaced by shade tree mechanics positioning of the shoes is incorrect. Pull a wheel and check yours. A 52 Chevy had the improved floating brake shoes and the way they work requires that the shoe with the short lining be placed in the front. Other than that if every thing else is correct then get a leg press machine and develop some muscle.
Execution time: 0.931 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:00 AM
