Username Post: Electric Choke Blew 10 Amp fuse        (Topic#343969)
carolinakid
carolinakid
Loc: Sanford NC
Reg: 08-27-03
04-11-17 10:00 PM - Post#2686127
Donny,
After 4 years, finally cranked up my 56, started right up but notice the electric choke wasn't opening. Choke is wired to number 12 spot on Power Plus Eight fuse box. The 10 Amp fuse in the 5 position on the box had blown. Choke is on a Edelbrock 1403 Carburetor. I replaced it with 15 Amp fuse or should I stay with 10 Amp fuse. Believe the original 10 Amp fuse that blew might have been of questionable origin. Thanks
aawtech
Loc: Bellmawr, NJ
Reg: 09-11-06
04-12-17 08:51 PM - Post#2686364
    In response to carolinakid
  • carolinakid Said:
Donny,
10 amps should be more than ample. Did it pop immediately, or was it a slow to blow situation? If immediate, the choke is shorted to chassis.
Donny
carolinakid
carolinakid
Loc: Sanford NC
Reg: 08-27-03
04-15-17 07:16 PM - Post#2686799
    In response to aawtech
Popped with in 20 seconds of startup.
aawtech
Loc: Bellmawr, NJ
Reg: 09-11-06
04-15-17 08:10 PM - Post#2686804
The only time it pops is when the choke is hooked up? If you disconnect it, does the fuse hold the circuit fine? If so, I'd say you have a short. do not increase the fuse size. need to dig deeper into this when I get back
Execution time: 0.187 seconds.   Total Queries: 12   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:49 AM
