Username Post: headlight relay wire gage        (Topic#343942)
CB56
CB56
Loc: Camarillo,CA
Reg: 12-27-02
04-11-17 08:58 AM - Post#2686009
Hi Donny, I have your Classic Update series in my 56 Chevy. I am upgrading to Halogen headlights using relays. Should I use a 20 or 30 amp fused circuit and is the wire gage in the in the update series ok or should I increase the size? If an increase is needed, what gage do you recommend?
Thanks, Chris
aawtech
Loc: Bellmawr, NJ
Reg: 09-11-06
04-12-17 09:53 PM - Post#2686365
    In response to CB56
Thanks, Chris
It depends on the draw of you lamps, if just normal halogens, you really don't need any relay or heavier wiring. The switch we supply is an upgraded unit, and the wiring is already stepped up. The enhancement relays were generally a band aide for an old system.
Donny
CB56
CB56
Loc: Camarillo,CA
Reg: 12-27-02
04-13-17 11:21 AM - Post#2686467
    In response to aawtech
Thanks Donny, I am just using standard halogens (H6024). I just wanted to make sure so that there were no issues going forward. You just saved me a little work.
Thanks, Chris
Execution time: 0.322 seconds.   Total Queries: 12   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:45 PM
