Username Post: hard getting in low and rev        (Topic#343878)
virg809
Loc: ks
Reg: 11-08-15
04-08-17 10:33 AM - Post#2685612
tried adjusting pedal play....do I need new clutch kit?
Bel Air kiwi
Bel Air kiwi
Reg: 04-24-14
04-08-17 01:54 PM - Post#2685640
    In response to virg809
Hi Virg809, Yes it's looking that way. They are the two non synchro gears so they get nasty first when the clutch isn't fully releasing. If the clearances are right that's usually the cause.
How old in miles is the old clutch plate and pressure plate?
Cheers Kiwi
04-08-17 02:03 PM - Post#2685642
I agree with Kiwi that the clutch probably isn't releasing fully. Adjust the linkage to reduce the pedal free play and see if that helps any.
virg809
Loc: ks
Reg: 11-08-15
04-09-17 04:06 AM - Post#2685688
adjusting linkage does not seem to help
2blu52
2blu52
Reg: 03-12-02
04-09-17 04:17 AM - Post#2685690
As said, time for a clutch. While it is apart pull the fly wheel and have it serviced as well. Don't ask me why I know this is a good idea.
THOMAS JEFFERSON
56sedandelivery
56sedandelivery
Loc: Everett, Wa.
Reg: 02-26-08
04-09-17 11:23 AM - Post#2685731
    In response to 2blu52
If the clutch is't releasing fully (misadjustment or wear), the gears would grind trying to get it into gear. He said nothing of that. Maybe the grease in the shifter box on the column has gotten hard or it's parts worn? Remove, clean, inspect, re-lube and replace, then re-adjust everything. We've seen photos others have posted, where the holes in the linkage have "wallowed" themselves out, and become "ob-longed"; re-weld and re-drill in those cases. Trans full of lube? If all the linkage works smoothly, is properly lubricated, and there's no grinding, then I don't know.
I am Butch/56sedandelivery.
Edited by 56sedandelivery on 04-09-17 11:26 AM. Reason for edit: No reason given.
2blu52
2blu52
Reg: 03-12-02
04-09-17 01:09 PM - Post#2685745
Hard to get into gear may mean it is grinding and maybe not. I still opt for the clutch repair, based on a little past experience. However you are correct there is a lot more to check on here than adjustment.
THOMAS JEFFERSON
Bel Air kiwi
Bel Air kiwi
Reg: 04-24-14
04-09-17 08:37 PM - Post#2685805
Hi Butch, good call, with a vehicle of this age it could be both. I wouldn't normally pull the flywheel unless an inspection shows damage from rivets or similar, or it was vibrating when used.
They do get out of flat over time but it's not a big deal. You would normally feel pulsing in the pedal if they are not flat.
It just depends on your budget and style of maintenance but you could probably just do the clutch driven plate and it would come out fine. For a customer you need to do the lot as they aren't interested in a do over in 30,000 miles to do the clutch cover and another plate. It also depends on the vehicle and driving style. There are options if you do your own work.
Cheers Kiwi
virg809
Loc: ks
Reg: 11-08-15
04-10-17 04:08 AM - Post#2685828
    In response to Bel Air kiwi
thanks to all, when 3rd gear went out I replaced tranny with a low mileage one and should have replaced clutch while I was at it, haven't had the car all that long and don't remember how it shifted before....guess clutch is next
04-11-17 09:44 AM - Post#2686018
  • virg809 Said:
.....when 3rd gear went out I replaced tranny with a low mileage one and should have replaced clutch while I was at it....
It is almost impossible for 3rd gear to fail. On a badly worn trans it may jump out of gear as you drive, but that's not the same thing. Can you describe how 3rd gear "went out"? This could help to diagnose other problems you might have which are not related to the clutch.
Also, you still haven't told us just "how" the trans is hard to get into low and reverse gears. Does it grind, or does it do something else?
virg809
Loc: ks
Reg: 11-08-15
04-11-17 11:01 AM - Post#2686028
the trans I took out has a broken part that made it jump out of 3rd gear....the trans I put in is a low mileage one....it grinds when putting in rev and low like when I stop and try to go...if I mess with shifting from 3rd to 2nd and try to double clutch sometime it will go into low or rev...sometime I just have to turn the eng off and put it in rev or 2nd
04-11-17 11:55 AM - Post#2686036
Ok on jumping out of 3rd gear. That's pretty much what I was hoping to hear when I asked the question.
As for low and reverse, that would be about a 99% likelihood of the clutch not disengaging fully. The other 1% would be the pilot bearing dragging.
virg809
Loc: ks
Reg: 11-08-15
04-11-17 01:10 PM - Post#2686045
friend said same about bearing not releasing, cant lube em anymore
04-11-17 02:45 PM - Post#2686069
You may be thinking about the throwout bearing, and you are correct that it can't be lubricated. If it failed, you would definitely know because it would be making really bad noises when you press the clutch pedal.
I was talking about the pilot bearing, which sits in a bore in the crankshaft. When this one fails it can cause the trans input shaft to continue turning with the crank even though you have the clutch pedal pushed all the way down. You have to remove the trans and clutch in order to replace this bearing.
virg809
Loc: ks
Reg: 11-08-15
04-12-17 03:53 AM - Post#2686158
yes I think he did say pilot brearing, thanks
50hotrod
50hotrod
Reg: 07-25-11
04-12-17 06:47 AM - Post#2686191
For the time being when stopped try shifting to 2nd gear first before going to 1st or reverse.
2nd gear has a synchro and should not grind going in. This will stop the trans gears from free wheeling, then quickly shift to the desired gear.
People done gone put their Bible's away
virg809
Loc: ks
Reg: 11-08-15
04-20-17 03:44 AM - Post#2687432
    In response to 50hotrod
got the tranny and clutch out, went to napa and orielly to borrow a pilot bearing puller, neither one would go in the hole.....guess I will have to use the pound in the grease way to get it out
Bel Air kiwi
Bel Air kiwi
Reg: 04-24-14
04-20-17 04:24 AM - Post#2687440
Hi Virg, if it's the phosphor bronze type leave it in a small jar of oil overnight so that it fully soaks the lube into the pores of the metal before installing it. Some guys squeeze them end to end to see if oil oozes out, if not more soaking, but generally overnight does fine. It should last at least another 50,000 miles or more if you soak it. Provided you put the car in neutral when you stop, and don't just use the clutch as a false neutral.
Cheers kiwi
Edited by Bel Air kiwi on 04-20-17 04:25 AM. Reason for edit: No reason given.
2blu52
2blu52
Reg: 03-12-02
04-20-17 06:15 AM - Post#2687454
I broke two pullers, one a Snap On trying to remove mine as a matter of routine repair when doing the clutch and flywheel. So I checked play with a new bearing and just left the old one in place, I did lube it with hi temp white grease however and it has been in place that way for 26,000 miles.
THOMAS JEFFERSON
virg809
Loc: ks
Reg: 11-08-15
04-21-17 03:39 AM - Post#2687571
trying to get the bearing out not in
04-21-17 07:18 AM - Post#2687588
To pull pilot bushings I always run a fine thread tap into them. For a Chevy it should be 5/8" or 16mm. If the bushing bore is badly worn, you may need to go larger than that.
Don't try to use the tap to pull the bushing. If it is really tight, all you will do is strip the threads you just cut. Instead, remove the tap after threading the bushing all the way through and run a screw into the threads. Keep turning the screw after it hits bottom and the bushing will come out. In a perfect world, you would have a steel ball to put into the bore before you run the screw in. This will keep the end of the screw threads and the bottom of the crankshaft bore from being damaged if the bushing is really tight.
56sedandelivery
56sedandelivery
Loc: Everett, Wa.
Reg: 02-26-08
04-21-17 01:17 PM - Post#2687625
You can VERY CAREFULLY split the bushing with a chisel. You don't want to score up the crank hole. Even a NARROW wood chisel will work; the material the bushing is made of is fairly soft. I have always used the "pack-with-grease-and-pou nd-it-out" method; a 3/8" drive, Craftsman extension,
"female end", is just the right size, and I use a brass hammer. I am Butch/56sedandelivery.
Bel Air kiwi
Bel Air kiwi
Reg: 04-24-14
04-21-17 08:52 PM - Post#2687696
Hi Guys I am sure Butch meant to say engineers splitting chisel, or key way chisel. The fourth from the left is the one.
He couldn't possibly have meant a wood working one that he also uses to open paint tins.
Actually a tiny nick won't hurt in the flywheel as the bush is an interference fit in it, but try not too.
Cheers Kiwi
Attachment: Splitting_chizel.jpg (4.85 KB) 8 View(s)
virg809
Loc: ks
Reg: 11-08-15
04-22-17 11:19 AM - Post#2687758
got it out, got the tool from orielly and filed down the fingers just a smidge and used a slide hammer , came out with 3 whacks
virg809
Loc: ks
Reg: 11-08-15
04-28-17 04:28 AM - Post#2688682
got my new kit, now to get it in
Execution time: 0.581 seconds.   Total Queries: 18   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:31 PM
