Username Post: Fan clutch        (Topic#343839)
rockfangd
rockfangd
Loc: Utica ny
Reg: 04-13-10
04-06-17 08:10 PM - Post#2685340
Hi all.
So last year I noticed my coolant temp was a little higher than normal when pulling hills on warm days. This on my 1990 5.7l k1500
It was also slow to warm up.
So I decided to replace the fan clutch, and while I was doing that I decided to replace the fan.
I went from the 7 blade steel fan to the 11 blade composite blade.
I now know that my fan clutch was not working, probably for quite some time. I dont ever recall hearing it while driving.
Now with the new clutch and blade I know it is working. It works nicely to warm the engine and it now stays perfectly around 190*.
Also with the 11 blade fan it wont need to run much to work efficiently which should help fuel economy and HP.
The fan blade was a bolt on swap that fits nicely.
Just thought I would share.
I also give credit to the GMT400 forum for the insite
https://www.rockauto.com/catalog/images/transp urpl...
Attachment: 20170326_142605_1491533289586.jpg (65.13 KB) 17 View(s)
Attachment: 20170326_145242_1491533289062.jpg (56.63 KB) 11 View(s)
Old School GM fan FOREVER
Edited by rockfangd on 04-06-17 08:11 PM. Reason for edit: No reason given.
scrambldcj8
Loc: MA
Reg: 04-06-03
04-07-17 04:11 AM - Post#2685359
    In response to rockfangd
Is that the H1 11 blade fan? Duramax fan...same?
Can you provide part numbers?
454cid
454cid
Loc: West Michigan
Reg: 02-18-12
04-07-17 11:00 AM - Post#2685416
    In response to scrambldcj8
I researched this a little awhile back. There are several blades that people use. A lot of them use a blade that came on a 4.3L V6, and some use a Duramax blade, which I think is an inch larger. I ended up just keeping my 9 blade steel/aluminum fan.
99 K3500 RCLB
rockfangd
rockfangd
Loc: Utica ny
Reg: 04-13-10
04-07-17 06:21 PM - Post#2685492
    In response to 454cid
I did post a link to the one I used.
Bottom line of the first post
454cid
454cid
Loc: West Michigan
Reg: 02-18-12
04-07-17 10:22 PM - Post#2685536
I tried following that link, and I get a square in the the middle of my screen, that's it.
I assume you bought the Dorman replacement for the 4.3L...... I think they used them on some 350's too.
99 K3500 RCLB
bowtie44s
bowtie44s
Loc: wv
Reg: 08-29-12
04-08-17 06:35 AM - Post#2685570
I put one on mine. I had the steel 4 blade fan on mine. I got my fan from a 96 S10 Blazer for $5. The Blazer had a different clutch but my clutch bolted right on.
Jeff
rockfangd
rockfangd
Loc: Utica ny
Reg: 04-13-10
04-08-17 10:49 AM - Post#2685598
    In response to bowtie44s
sorry. I dont usually use dorman.
FOUR SEASONS 36893
scrambldcj8
Loc: MA
Reg: 04-06-03
04-08-17 06:31 PM - Post#2685657
FOUR SEASONS 36893
Thanks.
.....Yeah, all I got with the link was a (blue?) square on the upper left of the page...
CowboyTrukr
CowboyTrukr
Loc: Salt Lake City
Reg: 06-20-09
04-08-17 09:48 PM - Post#2685671
http://www.rockauto.com/en/moreinfo.php?pk=2195760...
For those wanting a link, here you go
Greg
'00 Explorer XLT 4.0 V6 Auto
454cid
454cid
Loc: West Michigan
Reg: 02-18-12
04-08-17 11:34 PM - Post#2685677
FOUR SEASONS 36893
Yes, I too avoid Dorman. Sometimes that's all that's available besides OEM, Though. My wiper transmission, and interior door handle from Dorman seem to be okay.
That fan you bought wasn't too bad in price. My OEM fan, even on ebay is really expensive....approaching $200, if I recall correctly. It's a nine blade steel an aluminum fan. There are two things that bother me a bit about it..... it doesn't spin quite straight even with a new clutch, and it's kinda heavy. Your new plastic fan is obviously lighter, but does it seem to spin true? If I were to get one, I think I'd paint it black with one of those new paints that's supposed to stick to plastic.
99 K3500 RCLB
rockfangd
rockfangd
Loc: Utica ny
Reg: 04-13-10
04-09-17 01:53 PM - Post#2685743
It is twice as light and spins perfectly.
They are weight balanced when they are built to ensure they wont vibrate.
Very affordable also
Edited by rockfangd on 04-09-17 01:54 PM. Reason for edit: No reason given.
454cid
454cid
Loc: West Michigan
Reg: 02-18-12
04-09-17 06:05 PM - Post#2685776
What was the country of origin?
99 K3500 RCLB
rockfangd
rockfangd
Loc: Utica ny
Reg: 04-13-10
04-09-17 07:23 PM - Post#2685785
I am pretty certain it was USA.
That is why I went with 4 seasons.
Good brand with a good warranty
454cid
454cid
Loc: West Michigan
Reg: 02-18-12
04-09-17 10:44 PM - Post#2685812
Thanks.... maybe I'll change mine yet. Power Steering hoses and brakes come first though. I noticed a leak and grinding someplace today.
99 K3500 RCLB
rockfangd
rockfangd
Loc: Utica ny
Reg: 04-13-10
04-10-17 06:44 PM - Post#2685942
I love it so far. It holds the temp beautiful.
I have heard it works wonders for AC also. Blows colder at idle.
Mine is 55/3 so I cant judge that one
Vaughn
Vaughn
Loc: Colorado Springs, CO
Reg: 08-08-04
04-20-17 03:43 PM - Post#2687505
I had a composite fan lying around, so I decided to throw it on the 97 this afternoon.
Some things to think about:
The edges of the composite fan blades are very sharp, they will cut your fingers very easily even if they are a few years old. You might want to debur the edges or wear gloves to install.
Chevy engines operate in a clockwise rotation as you are looking at the vehicle from the front of the radiator, so the large nut on the fan unscrews in a CCW manner. You will want to use a long/large screwdriver stuck between two of the 10 mm bolts holding the fan pulley on and a large crescent wrench to undo the large nut, because the tension on the fan belt will not be enough to allow you to loosen the nut. For those unfamiliar with the water pumps that have the large threaded snout that the fan screws on, you cannot take the fan and pulley off by removing the (4) 10 mm bolts.
Lay the fan and thermostatic clutch down on the floor, then unbolt the clutch from the fan, (4) 13 mm bolts. Take the fan off of the clutch, being careful to keep the orientation in the same direction and set it on the floor. This will tell you how to install the new fan blades onto the clutch so that you are sucking air through the radiator rather than pushing it back through, which would be bad.
DO NOT assemble the fan and clutch at the same time. It will not fit into the shroud assembled. Stick the fan into the shroud remembering to orient it the same way that the metal fan is oriented. Then maneuver the clutch into the shroud and in front of the fan. Then you can assemble the clutch and the fan together.
Before you install the clutch and fan assembly, put some anti-seize on the threaded stub of the water pump, so it isn't as hard to remove the fan assembly next time.
Then thread the fan assembly onto the water pump stub, and tighten it down with the crescent wrench. Use the screwdriver stuck between two of the 10mm bolts to help tighten the nut. Don't go overboard tightening the nut, the fact that the engine rotates clockwise will help to tighten it as the engine rotates.
rockfangd
rockfangd
Loc: Utica ny
Reg: 04-13-10
04-20-17 06:26 PM - Post#2687528
    In response to Vaughn
My engine is a CCW rotation. Pretty sure anyway.
Also has 4 bolts that secure the clutch and waterpump pulley to the waterpump.
I took the top portion off of my shroud so I could put the assembled unit in all together
454cid
454cid
Loc: West Michigan
Reg: 02-18-12
04-20-17 07:48 PM - Post#2687537
I used a ratchet to put more tension on the belt with the belt tensioner when the belt alone wasn't enough to keep the pump from spinning. I have the traditional 4 bolt setup, not the big single nut, Though.
99 K3500 RCLB
rockfangd
rockfangd
Loc: Utica ny
Reg: 04-13-10
04-20-17 07:58 PM - Post#2687540
If you know how to position the wrench it will work on your side and make it easier.
Difficult to explain how it works though
1983G20Van
Loc: Bedford, Texas, USA
Reg: 11-13-02
04-21-17 09:28 AM - Post#2687596
  • rockfangd Said:
Hi all.
I pulled the 5 blade steel fan off my Express years ago and ran one of those for a couple of years. Then pulled it off for a GMT400 Tahoe tow package fan. Removed that for Impala electric fans. Removed that for Police Tahoe fans. The electrics could not keep the 350 cool even with a 454 radiator with a heavy trailer. Pulled the electrics and put a Duramax fan on it. The engine runs cooler with the Duramax fan than it ever has even though I put a 25% underdrive pulley setup on it. When the clutch actually engages on the Duramax fan the roar it makes has you looking for a medium duty truck.
Edited by 1983G20Van on 04-21-17 09:29 AM. Reason for edit: No reason given.
454cid
454cid
Loc: West Michigan
Reg: 02-18-12
04-21-17 11:05 AM - Post#2687606
Are you talking to me? If so I have no idea what you mean by "it will work on your side".
99 K3500 RCLB
Vaughn
Vaughn
Reg: 08-08-04
04-21-17 01:18 PM - Post#2687617
Replace the words "it will work on your side" with the words "it will work in your favor".
rockfangd
rockfangd
Loc: Utica ny
Reg: 04-13-10
04-21-17 06:07 PM - Post#2687675
Yes. Sorry. We all have different lingo lol.
It has to do with physics.
454cid
454cid
Loc: West Michigan
Reg: 02-18-12
04-22-17 07:20 AM - Post#2687711
I still have no idea what you're talking about.
99 K3500 RCLB
rockfangd
rockfangd
Loc: Utica ny
Reg: 04-13-10
04-22-17 11:35 AM - Post#2687746
It is hard to explain.
If you want to remove a fastener on a part that spins the best way to do it is to put the tool past the center of the part, that will give you leverage to help to loosen or tighten the fastener
Execution time: 0.333 seconds.   Total Queries: 18   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:55 PM
