Username Post: 2014 sierra ac/freon leaks        (Topic#343808)
george88gta
george88gta
Loc: new york
Reg: 04-23-03
04-05-17 12:49 PM - Post#2685134
Truck is a 2014 Sierra 1500. AC quit two weeks ago. Got it in to the dealer today and diagnosis was "freon very low". They topped it off ( free!) and checked for leaks. None found. They asked me to bring it back in two weeks or so and they will check freon charge. I read somewhere that these trucks have an issue with the aluminum/rubber lines leaking do to vibration and that GM came out with a bracket to support the lines. Anyone have any info on this? Is there a TSB that lists the part number for the bracket? Somewhat sounds like the issue that GM had with oil cooler lines leaking. Truck is my sons and he is in the Air Force, heading to Oklahoma for training and I would like to get this resolved before he goes.
LMC Trucks
george88gta
george88gta
Loc: new york
Reg: 04-23-03
04-05-17 01:23 PM - Post#2685135
    In response to george88gta
Found it! Look at this link http://sandyblogs.com/techlink/?p=3816
Part number for bracket is 23264893.
rockfangd
Loc: Utica ny
Reg: 04-13-10
04-18-17 05:11 PM - Post#2687232
I bet that is the problem. Probably too much load at the weak point of the line causing it to flex and crack. could be right at the fitting
My Cadillac had a similar problem
Would totally pass a leak test but under pressure it would leak out from where the hose mates with the aluminum line.
Do not put or let anyone put stop leak in your system.
Should be warranty.
they had that issue with trans lines, oil lines, etc...
Old School GM fan FOREVER
Edited by rockfangd on 04-18-17 05:13 PM. Reason for edit: No reason given.
george88gta
george88gta
Loc: new york
Reg: 04-23-03
04-19-17 04:14 AM - Post#2687290
    In response to rockfangd
I have been using the AC for about two weeks and truck goes in to dealer for a recheck tonight. I will hand them the info. I will let you know what happens.
george88gta
george88gta
Loc: new york
Reg: 04-23-03
04-21-17 07:23 AM - Post#2687589
I checked the temperature ( at the outlets ) and it was around 40 degrees. I knew their answer before bringing the truck in, "No problem, working fine." So we will drive it for a few more weeks and bring it in for a recheck. Hopefully we will get some warm weather to stress the system, it is 49 degrees here today.
rockfangd
Loc: Utica ny
Reg: 04-13-10
04-21-17 06:00 PM - Post#2687681
yup. Sounds like NY.
Heat today,
Ac tomorrow
george88gta
george88gta
Loc: new york
Reg: 04-23-03
05-09-17 04:21 AM - Post#2690375
Update. A/C failed again. Took truck back to the dealer. They verified, no/low freon. This time they found a leak in the condenser. Chatting with the parts department I found out that GM is having a problem with defective condensers and there is a back order on the part. Luckily, they had one in stock and it is being replaced today. More to follow.
rockfangd
Loc: Utica ny
Reg: 04-13-10
05-09-17 05:25 PM - Post#2690488
really. Wonder where they are failing so soon.
I am amazed that they had one.
george88gta
george88gta
Loc: new york
Reg: 04-23-03
05-10-17 03:57 AM - Post#2690552
Just guessing, but the hoses seem to have a lot of play. Maybe they did a cost reduction and removed a bracket or brace.
LMC Trucks
Execution time: 0.2 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:59 AM
