Username Post: '48 Chevy fleetline 350 swap questions        (Topic#343770)
bigbry230
Loc: Currently: Brooklyn, NY. ...
Reg: 03-09-11
04-03-17 07:25 PM - Post#2684865
Hi all
I am new owner of the 1948 Chevy fleetline aerosedan and I am thinking of swapping a v8 into it. I want to modify as little as possible. Has anyone done this swap? Any info would be greatly appreciated. Thanks!
Bryan
lofat46
2nd Year Silver Supporting Member
lofat46
Loc: Bloomingdale, IL
Reg: 08-12-13
04-04-17 05:39 AM - Post#2684928
    In response to bigbry230
Bryan, Congrats on your purchase. This is a simple, straight forward swap. First thing is get yourself a catalog for Chassis Engineering out of Iowa. One stop shop for everything you need from motor and trans mounts, new suspensions, everything. Best thing, it's all bolt in so there is very little change to the original frame, maybe drilling a few extra holes. Good luck.
www.chassisengineeringinc.com
1946 Chevy Fleetmaster 4-door Street Rod
Edited by lofat46 on 04-04-17 05:40 AM. Reason for edit: No reason given.
Broo102
Broo102
Loc: RANCHO CUCAMONGA, CA.
Reg: 09-30-14
04-04-17 08:43 PM - Post#2685055
I used the "muffin top" type motor mounts for my V8 on my 47 convertible.. They bolted to the frame. Make sure your angle of the engine is 3 to 4 degrees down and your diff. is the same degrees going upward.
Thanks!
Bru
John 3:16
32 Chev. 5 Win. Sports Coupe
Fun Pain
Reg: 03-13-17
04-06-17 11:39 AM - Post#2685270
    In response to Broo102
keep us posted, and have fun.
1948 Cheverolet 2 Door Stylemaster Corvette
To date image
https://drive.google.com/file/d/0B4Kme4TBETGtW EYwR...
Broo102
Broo102
Reg: 09-30-14
04-08-17 03:22 PM - Post#2685646
    In response to Fun Pain
Beautiful set up with a lift like that!
Thanks!
Bru
John 3:16
bigbry230
Reg: 03-09-11
04-15-17 07:42 AM - Post#2686728
Hey guys. Thanks for all the advice! This may be a stupid question but do I have to modify the steering column with this swap? I'd like to keep the car looking as close to stock as possible with the hood down.
Broo102
Broo102
Reg: 09-30-14
04-15-17 01:42 PM - Post#2686763
I didnt on my 47 convert., and I have an X frame also. I could not shift the car on the column however. the shift linkage and shift box hit the corner of the head and valve cover. had to give that up and put my 4 speed on the floor. Still looks kind of original; used a old school looking shift handle and knob.
Thanks!
Bru
John 3:16
04-15-17 06:40 PM - Post#2686795
I used the engine, trans and rearend in a 47 I had in 1967. So long ago, I do remember I used a floor shifter for the 3 speed trans. Think I got it and the hydraulic clutch from JC Whitney.
lofat46
lofat46
Reg: 08-12-13
04-17-17 05:48 AM - Post#2686957
If you go to a Mustang II suspension then you will be changing over to a rack and pinion steering. However you can modify your stock column to mate to the R & P. Years ago I had a machine shop cut and spline my stock column to fit a factory type rag joint when I installed a later steering box on the stock frame. The same could be done to install a u-joint (a much better choice than a rag joint) to mate to the R & P. Another option is to get an aftermarket column form Ididit or Flaming River. One or both makes a column that is thin that resembles the stock column. They offer them in chrome or paintable.
Broo102
Broo102
Reg: 09-30-14
04-20-17 05:28 PM - Post#2687530
    In response to lofat46
Bry
I used a Mustang II front with a Silverado front bracket so a serpentine belt system could be used.
the whole fit well.
Let me know if you need any pics or info
bru
Thanks!
Bru
John 3:16
Execution time: 0.227 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:56 AM
