Username Post: 305 Head gasket dilemma        (Topic#343453)
drakey
Reg: 03-20-17
03-20-17 09:14 PM - Post#2682502
1996 Chevy c1500
First and foremost I have the damaged side removed and found coolant in the 2 back most cylinders, Its the left side from the drivers position. The questions being: I read an article that advised changing both gaskets as well as replacing all "tension bolts". Keep in mind money is a problem, should I change both gaskets now or will i be OK with just changing the drivers side? I was also wondering what the chances of me breaking a head bold while torquing it, Am i so likely to break a bolt that I need to buy the bolt set?
Also, considering the old gaskets are Felpro im assuming this has been done before.
I Just don't want to f this up and have to spend another 90$ on gaskets.
Edited by drakey on 03-20-17 09:23 PM. Reason for edit: No reason given.
jbknight311
jbknight311
Loc: Fort Worth, TX
Reg: 11-27-06
03-21-17 05:44 AM - Post#2682546
    In response to drakey
On my 89 350 I had same dilemma. Same cylinders fail point on the one side and not much money or time.
I changed the head gasket only on that one side and reused the bolts. No problems after that and problem fixed.
I also re-torqued other side head bolts and some did take a turn or two to get back to spec.
98 C1500 Silverado extended cab 5.7 auto 2wd Fort Worth, TX.
03-21-17 10:21 AM - Post#2682600
    In response to jbknight311
There seems to be some debate about the Vortec using torque-to-yield head bolts (which is why drakey is concerned about them.) I am fairly sure this is incorrect, and instead it uses regular bolts for the heads. The intake uses torque-to-yield bolts.
Post #5 in this thread has GM's somewhat ridiculous method for torquing Vortec head bolts...might want to give it a read.
https://www.thirdgen.org/forums/tech-general-e ngin...
While it refers to the vin "R" engine which is the 5.7, the same will apply to the 5.0.
drakey
Reg: 03-20-17
03-21-17 12:14 PM - Post#2682619
    In response to someotherguy
Yes, them being torque to yield was my concern. But if they are not, That's great. Thanks for the input guys, ill reuse them once the weather clears up and Put up the results.
drakey
Reg: 03-20-17
03-22-17 12:00 PM - Post#2682766
Sorry for the double post, Couldn't remember how to edit... I wanted to ask what the head bolt placement is on the 305, could only find diagrams for the 350 is it the same? Should have kept track of that but lesson learned.
03-22-17 12:06 PM - Post#2682767
Yep, except for the displacement you will find pretty much most things between the 305 and 350 are the same. That's a gross oversimplification, but for your purposes it works.
drakey
Reg: 03-20-17
03-22-17 12:11 PM - Post#2682768
Thank you, That was the fastest reply I've gotten on any forum.
Impala65SS
Impala65SS
Loc: Sweden
Reg: 08-23-07
03-23-17 02:14 PM - Post#2682977
It's a good method IMO. 1) the initial minor torque is just to start the bolt more or less equally, while the angular torque is the actual, mechanically correct, method. 2) The sought effect is to elongate the bolts (of the same tensile strength) to obtain the same clamping force from each bolt hole. The longer bolts will require more angular torque than the shorter bolts, to produce the same clamping. I'd bet the angular torque figures are in linear proportion to the length of the bolts
Just in case, I'm preparing to eat my hat in a near future
http://www.youtube.com/watch?v=SXn2QVipK2o&a mp;fea...
drakey
Reg: 03-20-17
03-23-17 03:23 PM - Post#2682988
    In response to Impala65SS
So I torqued everything down using the old bolts and everything went fine. Just a few more odd things to hook up and it will be done. Would have been done today but I ran into a problem, Where the fuel lines go into the top. I'm pretty sure I'm missing some parts, I have two yellow rubber rings, one black and one metal washer.
Doesn't look right.
drakey
Reg: 03-20-17
03-30-17 06:40 PM - Post#2684231
Just to close this out, I was missing a washer for the return line. I bought a repair kit for 22$ just for the washer.
For anyone who may be interested you need a black o-ring on bottom metal washer in middle and yellow / orange ish (depending on the kit) on top.
Motor is back together, had a friend adjust the rocker arms and is running good (there is a slight tick). When I was test driving I did have coolant spraying from the plug in the radiator, hopefully I can just put some Teflon on it or replace the plug.
Thanks again for the help everyone.
Execution time: 0.656 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:25 PM
