Username Post: cam help        (Topic#343442)
gmcpau
Loc: mechanicsville va
Reg: 12-25-16
03-20-17 03:14 PM - Post#2682440
i have a 383 put together with speedpro dish pistons 2 valve reliefs i know not the best choice but i have a couple new sets laying around that where gave to me,a performer rpm intake, scat crank, scat 5.7 rods,scorpion 1.5 roller rockers, profiler 195 heads with 64cc combustion chambers, 2.02 intake valves 1.60 exhaust valves,pistons are .010 in the hole, 4.100 bore size head gaskets that compresses to .028 for a quench of .038 going to install in a 4000? lb truck with a tci street fighter turbo 350 with a 3000 stall converter with possibly a 3.73 gear. truck has 255/60/r15 tires on it . looking for cam recommendations. i was thinking about a howards hyd roller with .530 intake .545 exhaust lift, 233@ .050 intake duration 241 @.50 exhaust duration with 110 lsa or 112 lsa what do yall think also what size carb thanks
gmcpau
Reg: 12-25-16
03-20-17 03:37 PM - Post#2682444
    In response to gmcpau
truck will be used mostly on weekends with occasional track
03-20-17 04:36 PM - Post#2682460
Sounds like a good combo, the roller is the way to go with a pretty aggressive cam. At least a strong 750 carb, maybe even 850, but that may a little much for low speed street driving.
gmcpau
Reg: 12-25-16
03-21-17 03:17 AM - Post#2682528
thanks shepard one thing i forgot to mention. i am not sure on which headers 1 5/8 or 1 3/4 cant seem to find the 1 3/4 to fit my truck
rumrumm
rumrumm
Loc: Macomb, IL
Reg: 10-18-01
03-21-17 04:41 AM - Post#2682543
A Holley 3310 780 carb would be a good choice for a carburetor. IMO, I think an 850 may be a little big. Have you checked the DCR with this particular cam? If so, what are the results?
Lynn
"There's no 12-step program for stupid."
383 sbc, Eagle, AFR, SRP, CompCams, Edelbrock, Sanderson. Dyno #'s: 450 hp @ 5700, 468 ft. lbs. torque @ 4300.
http://photo.net/photos/Lynn%20Johanso n
03-21-17 04:58 AM - Post#2682551
The larger tube headers would give you a little more top end power all things equal over the more common 1 5/8.
gmcpau
Reg: 12-25-16
03-21-17 03:32 PM - Post#2682644
the dynamic cr i come up with is 7.97:1 that seems low to me maybe i am not calculating it right
03-21-17 05:28 PM - Post#2682669
Checked it by your figures, 10.8:1 static, don't know how you got 7.97? Hmm ok I see dynamic not static. Wallace racing has a good calculator, you would need the exhaust valve closing specs. Actually 8:1 dynamic isn't bad.
Edited by Shepherd on 03-21-17 05:45 PM. Reason for edit: No reason given.
MikeB
MikeB
Loc: Plano, TX
Reg: 08-28-03
04-01-17 02:06 PM - Post#2684545
  • gmcpau Said:
speedpro dish pistons 2 valve reliefs I know not the best choice
D-dish K-Bs would have been better, but those are perfectly good pistons. I have used them on a 383 with 70cc chambers.
Edited by MikeB on 04-01-17 02:10 PM. Reason for edit: No reason given.
Execution time: 0.215 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:09 AM
