Username Post: loud ticking noise after starting        (Topic#343441)
mlrailguy
Loc: Moses Lake,WA USA
Reg: 12-30-02
03-20-17 01:40 PM - Post#2682417
My 01 5.3 begins making loud ticking sounds shortly after starting. Sounds like a diesel After a minute probably, it clears up and sounds great. It started doing this when I switched to synthetic oil. I've gone back to conventional oil, but the noise still comes.
What could this be?
Just DUNE it
03-20-17 04:42 PM - Post#2682445
    In response to mlrailguy
It sounds as if the lifters are taking a while to fill up after sitting. Somehow, the oil feed must have gotten clogged or restricted, but I don't know how or why the synthetic oil could have caused this to happen.
junkman104
junkman104
Loc: Murphy N.C.
Reg: 01-25-14
03-20-17 04:57 PM - Post#2682449
Piston slap, common in cold weather. They all do it. Nothing to worry about. Google it!
BTW I only use dinosaur squeezings in mine
03-20-17 07:57 PM - Post#2682485
    In response to junkman104
Piston slap is more than likely the culprit, but that is more of a knocking noise. So if it is a higher pitched tapping noise it may be lifters, a lower pitched knocking noise is piston slap. Mine has a knocking noise for about 45 seconds after I start it up in very cold weather.
JaVeRo
Loc: East Texas
Reg: 02-02-06
03-21-17 08:47 AM - Post#2682584
    In response to wagonman100
check your oil pressure, it may be time for a new oil pump.
James
2003 S10 Blazer 4wd (wife's)
2001 S10 Crew Cab (wife's mail truck)
1996 K1500 (mine)
1979 GMC 3/4 ton 2wd 4spd with a "Gilley's" bumper sticker, my first brand new truck.
2006 K1500 Company Truck
2006 K2500 NV4500 4.10's
mlrailguy
Reg: 12-30-02
03-23-17 08:03 AM - Post#2682927
    In response to JaVeRo
Yes, it's more of a rattle than a tick. Like I said, sounds like a noisy diesel truck. Oil pressure is good. Will it hurt if I drive off while making all this noise?
Just DUNE it
junkman104
junkman104
Loc: Murphy N.C.
Reg: 01-25-14
03-23-17 05:33 PM - Post#2683013
Do you know a decent mechanic you can have listen to the noise? Problems like this are hard to diagnose on the interweb.
TwentyBucks
Loc: Cape Cod, MA
Reg: 11-06-07
03-24-17 06:00 AM - Post#2683057
My 03 Suburban does the same thing when it is cold out, I don't worry about it and it goes away after about 15 seconds. 175,000 miles on it.
2018 Chevy Suburban LT 355HP 21 MPG
2002 Honda Civic commuter car. 261,000 miles 39MPG
03-26-17 01:07 PM - Post#2683448
    In response to TwentyBucks
Shouldn't hurt to drive it while making the noise. You can only really hear mine under load.
mlrailguy
Reg: 12-30-02
03-27-17 06:29 AM - Post#2683591
Thanks guys, I was really worried that a new engine was going to be needed.
If I would replace in the future, should I stick with 5.3 or go with something bigger?
Just DUNE it
Ray1999Z71
Ray1999Z71
Loc: Taylorsville KY
Reg: 04-11-17
04-11-17 06:27 AM - Post#2685983
My 99' is for sure a lifter noise. Right at start-up you can hear them. If you give it just a little gas they pump up and are fine. 330,000 miles on mine. Still runs strong.
Dad always said "It'll be aight!"
sprog777
Reg: 03-27-10
07-09-17 02:50 PM - Post#2699342
    In response to Ray1999Z71
my Tahoe use to do it and it stopped own its own? It was loud and u could here it from 100 feet away.
sprog777@yahoo.com
1979 K5 Blazer
2001 1500 z71 ext.cab
1999 Chevy Tahoe 4wd
1999 chevy z71 ext.cab
1966 Mustang coupe
1967 rs Camaro
1992 Mazda Miata
2009 ultra classic electra glide
1986 Gli
jearlc
Loc: Arkansas
Reg: 12-12-05
09-16-17 06:46 AM - Post#2707805
    In response to sprog777
My 04 Avalanche made that noise. Turned out to be a lifter. common with the 5.3
69_BOWTIE
Loc: WYOMING,USA
Reg: 02-27-02
09-17-17 07:57 AM - Post#2707902
    In response to jearlc
Yes hard to determine your sound over the web ,mine does it and I have determined it to be piston slap. Drives me freeking nuts but have to live with it. Truck has 170 k miles on it and runs pretty dam good , go listen to some you tube videos to help you see if yours is a tick or knock
2001 Silverado 4X4
2005 FXDWGI
69 CHEVY Short Step
63 IMPALA 2/DR HRDTOP 327
jktucker92
jktucker92
Reg: 02-05-17
09-18-17 07:59 AM - Post#2707999
    In response to 69_BOWTIE
Both the piston slap and lifter noise is relatively common in the 5.3L.
I've had a '03 Suburban that had a lifter noise, and an '02 Tahoe that had the piston slap. Piston slap is very common in these engines and there is a TSB about it. My '02 Tahoe had the piston slap issue from about the time it was new, and the dealer said it was normal for the design. We sold it with 150,000 miles and never had an issue other than the noise. It's more of a loud knocking noise than a ticking noise. The '03 Suburban developed a ticking noise that turned out to be a failed lifter. The roller lifter stopped rolling and gouged the camshaft. For that engine, the camshaft had to be reground and the lifter had to be replaced. Unfortunately, replacing the lifter on these engines requires the head be removed. With as common as these problems are, I'd expect there to be videos posted with the two noises, but I haven't every looked.
Execution time: 0.192 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:24 AM
