Username Post: Measurements Help        (Topic#343402)
fuzz1957
Loc: NE IA
03-18-17 08:36 PM - Post#2682145
Need some help with some measurements - from 1964 SS Impala front door panel.
1. Width of center wide pleat - where SS insignia is attached.
2. Diameter of SS insignia.
3. Width of small pleat - the pleats on each side of center wide pleat. Need measurement of width of one pleat.
Other measurements needed:
1. 1964 front fender insignia/flags for 327 - heighth & width.
2. 1962/63 front fender insignia/flags for 327 - height & width.
Thanks in advance for the help.
Fuzz
junky
Loc: Northeast CT
Reg: 06-27-10
03-19-17 08:36 PM - Post#2682290
    In response to fuzz1957
I found this in the 1962 assembly manual, section 580, sheet 13.00, page 405. This is for the 409 emblem. The double flag emblem hole placement is probably in the assembly manual also, but so far, I haven't seen it. If I find it, I will post the reference for you.
pvs409
pvs409
Loc: Sergeant Bluff, Iowa
Reg: 01-10-05
03-19-17 10:14 PM - Post#2682306
    In response to junky
The trouble with that factory drawing is where are the 2 horizontial lines(20 /15) and the two vertical lines -where are they measured from?
I have never seen a 62 fender flag template. I could never figure out how to use that factory drawing.
I made 62 flags and 409 fender templates off my original fenders.
I think Fuzz wants emblem size, not location on the fender -but I might be wrong.
Paul
57 BelairHT 283/270hp 4 spd
62 ImpHT 327/300 4 spd
62 Imp CV SS 327/300HP 700R4
62 ImpHT SS 409/482 stroker 4 spd
62 Imp SS 409 - 5 spd Convertible under frameoff
Website http://paulstensland.com/
[image]http://chevytalk.org/sm/26453.jpg[/ima
fuzz1957
Loc: NE IA
03-20-17 07:36 AM - Post#2682372
    In response to pvs409
Thanks Junky and Paul.
Paul, you're correct - just want the measurements that I asked in first post. Redoing my 57 interior and want to copy the looks of the 64 SS interior. Instead of SS insignias on door panel, looking for another insignia to take its place. That's why I'm looking for measurements. Would be open to suggestions too.
Still need all measurements.
Thanks, Fuzz
fuzz1957
Loc: NE IA
03-20-17 04:04 PM - Post#2682439
Anyone have a tape measure or ruler?
Fuzz
BG64SS409
BG64SS409
Loc: Edmonton,Alberta Canada
Reg: 05-03-08
03-20-17 08:17 PM - Post#2682490
My repop interior is as follows
1. Width of center wide pleat - where SS insignia is attached. 6 3/8"
2. Diameter of SS insignia. 2 1/4"
3. Width of small pleat - the pleats on each side of center wide pleat. Need measurement of width of one pleat. 1"
Hope that helps..
Brett
64SS Impala,Original documented numbers matching 1 of 36 Canadian made SS409 340hp/PG
2013 Callaway Suburban, supercharged 450hp
Edited by BG64SS409 on 03-20-17 08:24 PM. Reason for edit: No reason given.
fuzz1957
Loc: NE IA
03-21-17 07:12 AM - Post#2682572
    In response to BG64SS409
Thanks Brett, very much appreciate you taking the time to help.
Fuzz
Still need front fender emblem sizes.
Execution time: 0.61 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 02:13 PM
