Username Post: Cleaning oxidized Aluminun wheels?        (Topic#343368)
PolarBadger
Infrequent Contributer
Loc: Tennessee
Reg: 10-30-16
03-17-17 09:31 AM - Post#2681959
Ok so I just got an s10 with some solid aluminum wheels and i like the wheels however the rear ones are newer because when we cleaned all of them up threw some wax on and they still look dull and the rear shined up a little bit (just used regular wax to see if they would even shine before I used aluminum polish) do I need to strip them and re clear them or what can I do?
Edited by PolarBadger on 03-17-17 09:32 AM. Reason for edit: No reason given.
SleeperSS
Loc: Spanaway, Wa
Reg: 10-17-04
03-17-17 09:18 PM - Post#2682030
    In response to PolarBadger
Sounds like the clear coat is failing. No amount of polish is going to help. Best bet is to strip then polish. It's a lot of work.
U.S.C.G. "So others may live"
'96 S-10 SS
'02 BlaZeR2
65_Impala
Reg: 12-29-02
03-20-17 10:07 AM - Post#2682388
If the coating is good without signs of oxiding underneath then try solutions that you'd use on paint first, like rubbing compound by hand or a rotary polisher. The coating on the fronts might be tarnished by brake dust.
Senior Chevytalk Moderator
04-02-17 08:23 AM - Post#2684614
    In response to 65_Impala
I used Mother's Aluminum polish on mine.
I have pics here: http://www.chevytalk.org/fusionbb/showtopic.php?ti...
The wheels cleaned up nicely.
tommy49
tommy49
Loc: Kaleva, Michigan
Reg: 09-28-12
04-06-17 07:13 AM - Post#2685224
    In response to SleeperSS
I was getting corrosion under the clearcoat on the Silverado wheels. Had them sandblasted and powder-coated matte black, $50 a wheel.
Tommy
49 Deluxe Sport Coupe, 55 235, 700r4, Blazer rear axle, 4 wheel power disc brakes.
Execution time: 0.241 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:47 AM
