Username Post: Draining Coolant 235ci        (Topic#343350)
Marcus62c10
Marcus62c10
Loc: Portland Oregon
Reg: 10-06-16
03-16-17 03:09 PM - Post#2681835
Greetings Chevy Brethren,
I've seen some slick coolant drains installed on 235 blocks when guys have them apart.
Unfortunately, my 235 does not not have a block drain. When it's rebuild time I will definitely add one.
In the meantime, I'm wondering if anybody knows of a way to get the coolant level below the head without making a mess? Draining the radiator does not drain the head.
If you're wondering why I want to drain the coolant out of the head, I'm planing on pulling it this weekend.
Thanks for any tips.
Cheers,
-Marcus in Portland Oregon
bobschevytrucks.com Ecklers Chevy Trucks
Bel Air kiwi
Bel Air kiwi
Reg: 04-24-14
03-17-17 12:12 AM - Post#2681908
    In response to Marcus62c10
Hi Marcus. You can pull the thermostat and suction pump it out, or take out a welsh plug that is easy to get at knock that out.
Cheers kiwi
Marcus62c10
Marcus62c10
Reg: 10-06-16
03-17-17 10:09 AM - Post#2681965
    In response to Bel Air kiwi
Cheers kiwi
Hi Kiwi, thanks for the idea.
I'll suck it out the thermostat hole...duh!
cheers brother!
03-18-17 10:23 AM - Post#2682081
When you said your 235 "does not not have a block drain" do you mean it doesn't have a drain cock, or do you mean it doesn't even have the hole (possibly with a plug in it)?
Marcus62c10
Marcus62c10
Reg: 10-06-16
03-20-17 10:31 AM - Post#2682395
Hi Ray,
I meant there is no petcock. Sounds like my understanding is off? I thought guys with petcocks in their 235 blocks had drilled and tapped. Are you saying that there is a drain with a threaded plug?
Thanks for chiming in,
FYI for anyone reading down the line, I ended up foregoing pumping coolant out of the thermostat housing and just pulled the top of the lower radiator hose off the water pump and aimed it at a clean bucket immediately below. It was a reasonably tidy and quick solution.
03-20-17 11:05 AM - Post#2682398
http://www.jims59.com/59impala/images/0820a MotorLt...
Start at the rearmost exhaust port and go straight down until you see the drain cock. Every one of these engines I have ever seen has this hole. If yours doesn't have a drain cock in there it should have a pipe plug.
Marcus62c10
Marcus62c10
Reg: 10-06-16
03-20-17 11:56 AM - Post#2682405
That's fantastic!
Thanks for the detail Ray.
Much appreciated.
-Marcus
03-20-17 02:44 PM - Post#2682430
So which does yours have - a drain cock or a plug?
Marcus62c10
Marcus62c10
Reg: 10-06-16
03-21-17 03:38 PM - Post#2682637
Hey Ray
Yup, it does have a plug!
The accelerator spring is attached to it; I didn't look closely enough to notice the threads. Previously thought that was just a post for the spring! Nope!
Cheers, next time I need the coolant out I'll try it out
-Marcus
03-21-17 05:46 PM - Post#2682658
This is the first time I have heard of anyone connecting a spring to that plug, but if it was the most convenient spot, I guess there is no harm done. If you ever need to remove that plug in the future, that would be a good time to replace it with a normal drain cock. It should be standard 1/4" NPT thread, the same as the radiator drain.
Marcus62c10
Marcus62c10
Reg: 10-06-16
03-22-17 10:35 AM - Post#2682749
Thanks for the detail on the threads Ray; I'll grab a drain cock next time I'm at the hardware store.
Ya, throttle works fine so I guess that's a reasonable place to hang the spring off of!
Cheers, thanks for the input
-Marcus
Execution time: 0.423 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:11 PM
