Username Post: "generator" light stays on while engine is running.... (83 1/2 pickup)        (Topic#342909)
World Domination
Reg: 03-01-08
02-26-17 09:00 AM - Post#2678593
83 1/2 pickup
My generator light stays on while the engine is running. It seems 1/2 as bright as compared to the brake, choke and oil pressure warning lights.
What i've done so far:
1) Measured battery voltage at 12.5, then started the engine. No change in voltage.
2) 2-3 hours later, tested alternator output with the engine running with the voltmeter. Red probe to the B+ terminal and then black probe to the body of the alternator. So with the engine off, 12.4ish and with the engine running no change.
3) i test lighted both wires in the plug that plugs into the top of the alternator (terminals 1 and 2 or "R" and "F"). With the ignition on; Both wires have power, but the smaller brown wire (terminal 1 or "R") is dimmer than the larger red wire (terminal 2 or "F").
So, i used the voltmeter; The larger red wire has 12.4-8 ish while the smaller brown wire, 6.3-5 ish.
4) i jumpered terminals 1+2 while the engine was running and the plug plugged in. The battery stayed at 12.08 V
And as far as i can tell the gen light stayed on, again seems 1/2 lit compared to brake, oil, choke lights.
Next?
02-26-17 11:30 AM - Post#2678614
    In response to World Domination
Your voltage readings should be higher with the engine running. I'd say you have a bad alternator.
02-26-17 01:16 PM - Post#2678635
Next?
Take the alternator to a auto supply and have it tested.
grumpyvette
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
02-26-17 04:39 PM - Post#2678668
    In response to acardon
Execution time: 0.182 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:49 AM
