Username Post: 69 Nova Deluxe side Molding clips        (Topic#342859)
MonteMike79
Loc: Erie, PA
Reg: 11-29-16
02-23-17 03:19 PM - Post#2678242
Hey guys, have a '69 Nova. Car originally came with the deluxe lower side moldings and rocker moldings. Previous owner removed the skinny moldings just above the rocker moldings, now I want to put them back on. Does anybody have a part number or source to buy the plastic clips used to mount these ? I have pictures of them, but can't find a place to buy them and/or part numbers.
Here is a picture of the clips that somebody sent to me:
Thanks for your help
Edited by MonteMike79 on 02-23-17 03:23 PM. Reason for edit: No reason given.
nickmac
nickmac
Loc: Tennessee
Reg: 02-13-07
02-23-17 05:15 PM - Post#2678256
    In response to MonteMike79
https://www.yearone.com/Catalog/1962.74.nova/body/... try this, they also have a kit that has the molding and clips. Welcome to CT.
Dan
'16 Chevy Traverse 3.6 FWD
'04 Chevy K1500 Silverado 5.3 4x4
MonteMike79
Loc: Erie, PA
Reg: 11-29-16
02-25-17 06:17 AM - Post#2678467
    In response to nickmac
Thanks I will have to give that a shot, I called YearOne about it since there are no pictures, the girl on the phone was very nice.
nickmac
nickmac
Loc: Tennessee
Reg: 02-13-07
02-25-17 07:49 PM - Post#2678550
I see you're from Erie. I lived in Warren County up until 2 years ago. I had enough of the snow.
Dan
MonteMike79
Loc: Erie, PA
Reg: 11-29-16
02-26-17 06:13 AM - Post#2678581
We haven't had much this year, most of January was pretty mild, and the last couple of weekends we've had record highs in the mid 70s. I'm not missing the cold or snow this winter.
Junkyardwarrior
Loc: Yuma AZ
Reg: 02-25-15
03-02-17 12:36 PM - Post#2679362
If YearOne doesn't have what you need, there is also classicindustries. I don't know if you've checked there yet, but from what I have seen you can basically build a whole Nova from there.
MonteMike79
Loc: Erie, PA
Reg: 11-29-16
03-04-17 06:05 AM - Post#2679619
    In response to Junkyardwarrior
I've searched everywhere I could think of, YearOne seems to be the only ones to have anything. I will have to give them a shot and see what I get.
Thanks for your help guys
MonteMike79
Loc: Erie, PA
Reg: 11-29-16
05-16-17 11:55 AM - Post#2691579
I ordered the clip set from YearOne along with the moldings, which are on backorder. The clips showed up today and they aren't the right ones like the factory used. They are a push in type clip instead of the plastic clips that go onto the studs. Does anybody have any sources for the plastic type clips ? Without the molding being here I don't know exactly what size clip I need to look for.
Any help appreciated
MonteMike79
Loc: Erie, PA
Reg: 11-29-16
06-10-17 01:02 PM - Post#2695370
Finished putting the moldings on today. I found an old post on a Nova site from a guy who listed some clips he used. I ended up using the same clips he did, which were for a '71 Mopar for the fender, door, and front quarter pieces. The pieces behind the rear tires I used GM wheel opening molding clips. Also used a metal clip on the front of each door with a stud and nut from the backside. The car looks like it should now with all the moldings it originally came with.
__________________
Edited by MonteMike79 on 06-10-17 01:02 PM. Reason for edit: No reason given.
Execution time: 0.264 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:45 AM
