Username Post: TBI in a GMC 6000        (Topic#342765)
Mayhem
Mayhem
Reg: 02-19-17
02-19-17 03:43 PM - Post#2677494
Hello forum first of all I hope I'm placing this in the right spot but I have a early 80'GMC 6000 that I am want to transplant a 92 model 5.7 TBI into I have the whole doner truck to get wiring harness and all I hope someone here has done something similar and might have a few pointers anyways hope to hear from you soon.
TIA Mayhem.
02-20-17 08:08 AM - Post#2677577
    In response to Mayhem
I'd wonder if a TBI 5.7 has enough torque to get that big sucker moving?
Is the current engine in the truck gas, or the diesel? If diesel, I'd wonder if the transmission has the correct bellhousing to fit a small block. Pretty sure the pattern on the big Detroit is totally different from regular GM gas engines.
Dunno a whole lot about those medium duty trucks though.
Mayhem
Mayhem
Reg: 02-19-17
02-20-17 03:49 PM - Post#2677665
    In response to someotherguy
Thanks for the reply it was originally a Small block truck from the factory had a nylon oil pressure line get against the exhaust manifold early last year and in no time a connecting rod almost went through the side of the block it was a 4 bolt main 350, switched it to a 366 from another truck I had and last week pulling a hill it cracked a head and to be honest it never had the power the small block had, the truck I have the TBI 5.7 in was one I picked up for $200 about 6 months ago I mainly bought it for the transfer case the frame is rusted in two over the rear end and the only thing holding the front to the rear of the truck are the leaf springs.
Right now I am thinking of carbureting the thing just because today while getting everything together I noticed that this 5.7 must have been replaced at one time because it has a fuel pump block off plate in the side of the block.
02-20-17 11:08 PM - Post#2677758
Many of the TBI engines have the fuel pump blockoff plate, so don't let that mislead you. Take it off and check the cavity; not all were finished out to allow the pump and pushrod to work correctly.
Mayhem
Mayhem
Reg: 02-19-17
02-21-17 01:20 PM - Post#2677847
I have it out and on the stand now tomorrow will pull the intake manifold it has the hole for the fuel pump rod whether or not the cam is lobed for a mechanical pump I will see tomorrow.
Execution time: 0.291 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:41 AM
