Username Post: 66 Impala w/ Corvette heater/blwr switch        (Topic#342757)
SEV SKC
SEV SKC
Loc: Alsace
Reg: 03-24-13
02-19-17 10:46 AM - Post#2677440
I pm d this to Donny but maybe someone else has an idea this Sunday so I can continue in the garage.
Donny,
Need your help here.
I am currently rewiring my 66 Impala using the Classic Update kit.
The heater/blower switch is a INDAK 3.223.794 type switch, so not
original and the T-shape plug with the kit does not fit, and I will
have to rewire the connections.
I found that the INDAK 3.223.794 came with the 66 Corvette.
Your Classic Update kit for the 66 Corvette (as well as my 66 chassis
manual for the Corvette) lists the connection colours as follows:
[OR] [Y] [LBL] (heater switch)
[BRN] (heater feed)
But when comparing the 1/2/3/M terminals to the original T-shaped plug
connections, the correct wiring would be
[OR] [LBL] [BRN](heater switch)
[Y] (heater feed)
How should I do my connections?
Thank you in advance for your valuable help
Car is original ac
Konrad
Konrad
66 Impala ragtop 383 M20
2010 Camaro SSRS 3 pedals
Edited by sev skc on 02-19-17 10:48 AM. Reason for edit: No reason given.
Execution time: 0.21 seconds.   Total Queries: 12   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:53 AM
