Username Post: Need recommendations for a chainsaw        (Topic#342696)
Johnny468
Johnny468
Loc: Richmond, Va.
Reg: 10-24-08
02-16-17 12:28 PM - Post#2677029
I'm looking for recommendations for a small gas chainsaw for home use. Will only be using to cut up fallen branches less than 12" diameter. I'm willing to pay more up front since I'd only like to make this purchase once. Looking for reliability and durability.
Thanks, Johnny
1965 Impala SS
505/4-speed/3.90
65_Impala
Reg: 12-29-02
02-16-17 04:51 PM - Post#2677045
    In response to Johnny468
Around here, the small gas powered equipment the pro's are using is mostly Stihl so that pointing to it being good stuff.
I've got a small MCCULLOCH saw that's been in the family 20+ years and it still starts and runs great. It has always run smooth and it is easy to hold onto. The only repairs besides replace chains was replacing the coil + electronic ignition module a couple of years ago. The saw is so old I couldn't even get a new part so I put a used one in it that cost $5 off Ebay.
I had a Poulan in my hands last year and it vibrated enough to make me hate using it after 5 or 10 minutes.
100 CHEVY
100 CHEVY
Loc: Helena,Missippi,U.S.A.
Reg: 12-09-04
02-16-17 05:05 PM - Post#2677046
I use Stihl chainsaws.
But,for around the house or close to it,I have a Remington electric chainsaw.Has a 12" bar and will cut pretty big stuff.It also has a long pole I can attach it to for limbs up on trees.
Mike.
rcr3
rcr3
Loc: Manheim Pa. U.S.A.
Reg: 11-24-02
02-17-17 05:46 AM - Post#2677099
I have a Stihl 024 I've used for over 20 years.Very dependable.
'12 Cruze RS LTZ
'73 Nova hatchback Sold 12/23/12
'37 Chevy cp.SOLD!!6/7/14
'74 Nova Custom cp.
'73 Nova pro-street project
'17 Chevy Trax LT
'00 S10 Ex cab
'06 Z71 Sierra Ex Cab
'67 Camaro survivor
Belair-o
Reg: 03-26-07
02-17-17 07:16 AM - Post#2677105
    In response to rcr3
I have a Stihl arborist chainsaw that I love (MS-192-T). It is light weight, cuts fast with it's thin-kerf blade - one of the best tools I have ever bought.
CowboyTrukr
CowboyTrukr
Loc: Salt Lake City
Reg: 06-20-09
02-18-17 09:06 PM - Post#2677364
    In response to Belair-o
Stihl makes great saws.
Others swear by Husqvarna.
Greg
'00 Explorer XLT 4.0 V6 Auto
Johnny468
Johnny468
Loc: Richmond, Va.
Reg: 10-24-08
02-20-17 11:46 AM - Post#2677627
    In response to CowboyTrukr
Thanks to everyone for their input, looks like Stihl it is. There's a dealer right here in town. I'll follow up after I go over to see them.
Johnny
1965 Impala SS
505/4-speed/3.90
JimKshortstep4x4
Chevytalk Moderator & "14th Year" Silver Supporting Member
JimKshortstep4x4
Loc: Muskegon, MI, USA
03-02-17 04:51 PM - Post#2679407
I have a Stihl and a Husqvarna, both 16" I like the Husqvarna for small branches up to 8" but anything larger, the Stihl is my go to chainsaw.
The Husqvarna has had fewer problems then the Stihl overall but I like both.
66 Impala SS, 396, TH 400
69 El Camino, 350, TH 350
2plus2
Loc: Mission,BC
Reg: 02-03-05
03-04-17 05:25 PM - Post#2679703
Dont waste your time with the easy start or chain adjust
Get the reg model
I have a MS250 and its a awesome saw
69 Canadian Pontiac 2+2
Johnny468
Johnny468
Loc: Richmond, Va.
Reg: 10-24-08
03-16-17 07:43 AM - Post#2681765
    In response to 2plus2
I decided on an Stihl MS251. So far everything looks good, although it is a little tricky to start when cold. Putting it to work on some downed limbs this weekend, will follow up afterwards.
Johnny
1965 Impala SS
505/4-speed/3.90
Johnny468
Johnny468
Loc: Richmond, Va.
Reg: 10-24-08
03-19-17 11:08 AM - Post#2682210
I spent all day Saturday cutting up downed limbs and could not be happier with this saw. I had the dealer explain the proper cold start procedure and it fired up perfectly. It's very well balanced and powerful. It has the standard chain adjustment which works very well. The chain oiler appears to be working properly. I also really like the gas and chain oil filler caps. From what I've seen up to this point the Stihl MS251 is a top quality saw which I would highly recommend for home use.
Johnny
1965 Impala SS
505/4-speed/3.90
Custom_Deluxe_20
Custom_Deluxe_20
Loc: Stevens PA USA
Reg: 04-05-02
07-23-17 05:03 PM - Post#2701100
When starting , choke but do throttle, they flood very quickly
92 SWB 4X 305 5peed Powetrax out back Posi-lock ft 72 LWB fleet, 454,400 t,12 bolt w/3.73 and locker #3 Roll on forever
grumpyvette
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
07-24-17 06:22 AM - Post#2701159
    In response to Custom_Deluxe_20
youll generally get longer life with less issues if you use the 40:1 fuel and take the time to fill the chain lube tank before every use,
soak the chain and bar down every hour or so with MOLY spray also makes the chain last noticeably longer and cut better.
https://www.zoro.com/crc-dry-moly-lubrican t-aeroso...
let the chain lube run low on lube and it wears very rapidly
READ THIS LINK
Edited by grumpyvette on 07-24-17 06:43 AM. Reason for edit: No reason given.
07-24-17 09:08 AM - Post#2701185
    In response to grumpyvette
Around here you have to have a "permit to carry" to buy one.
Duke
Duke
Loc: Earth (sometimes)
Reg: 04-28-03
08-25-17 10:34 AM - Post#2705561
    In response to acardon
Don't by a Poulan Chainsaw, POS!
http://s1245.photobucket.com/albums/gg590/MTBingNi ...
'55 Bel Air Sports Coupe
'67 Corvair Monza Convertible
Execution time: 0.3 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:02 PM
