Join the Community today
Username Post: Progress at last!        (Topic#342204)
Nailheadv8
Nailheadv8
Loc: Gardena, CA
Reg: 09-05-07
01-25-17 09:29 PM - Post#2673573
Attachment: DSCN4224.JPG (320.36 KB) 26 View(s)
A PROUD MEMBER OF THE BABY BLUE T-SHIRT BROTHERHOOD
WagonCrazy
WagonCrazy
Reg: 06-07-05
01-25-17 09:55 PM - Post#2673578
    In response to Nailheadv8
Clue us in George...what have you made for progress?
Is this the ElCo you drove to CFAC last year?
Nailheadv8
Nailheadv8
Loc: Gardena, CA
Reg: 09-05-07
02-04-17 05:51 PM - Post#2675199
    In response to WagonCrazy
The progress so far is ,that now I have a working A/C and heater. While the A/C shop had the front end off to replace the condenser, I took the grille home, removed the tarnished chrome strips, and painted the grille semi-flat black.
The engine has an HEI distributor and the wiring was from the old points system ( maybe 18 ga.), I replaced it with a 10 ga. wire from the fuse box directly to the dizzy and changed the plugs. What a difference that made!! a proper tune-up on the carb and I now have a much better performing car.
I also discovered that the fuel pump was leaking and not providing enough gas to keep up with the demands of the 383 stroker engine. I have the pump on hand and when the weather a ( and my damn sinuses ) cooperate I will install it. More later!! I have the parts for the interior and a new radio and speakers to install.
swbatt
West Coast Show Support
swbatt
Reg: 03-25-01
03-12-17 02:18 AM - Post#2681018
You are motivating me George, that sounds like a whole bunch of progress. Good job. I can't believe six month to next CFAC. Now I need to get going.
Execution time: 0.241 seconds.   Total Queries: 18   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:05 AM
