Username Post: Engine compartment wiring harness for 61 belair        (Topic#341935)
Ole61
Ole61
Loc: Ohio
Reg: 08-11-16
01-16-17 08:09 AM - Post#2671535
Donny I was referred to you on 61-64 for.I am looking into engine harness for 61 belair,the engine is a 454 with 400th and he I ignition
aawtech
Loc: Bellmawr, NJ
Reg: 09-11-06
01-16-17 01:27 PM - Post#2671625
    In response to Ole61
OK, it will be a somewhat custom deal. The Dash harness will need to be modified in the field or ordered new to accommodate the HEI. We modify the engine side for you. The T400 is a whole different issue. You'll need the switch and bracket to carry the downshift switch. We can probably use an off the shelf harness from a later car to activate it once you have the switch and bracket assembly.
Donny
Ole61
Ole61
Loc: Ohio
Reg: 08-11-16
01-16-17 06:58 PM - Post#2671691
    In response to aawtech
What all needs to be done to dash harness for hei the motor starts and runs
aawtech
Loc: Bellmawr, NJ
Reg: 09-11-06
01-16-17 08:45 PM - Post#2671725
There should have been a jumper wire and instruction sheet. not something we can do in discussions here.
Donny
Execution time: 0.257 seconds.   Total Queries: 15   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:20 PM
