Username Post: Mech fuel pump replacement problems        (Topic#341915)
mikeag81
Loc: Western PA
Reg: 10-26-14
01-15-17 02:08 PM - Post#2671377
I recently replaced the mechanical pump on my Impala. When I first put it on and started it up there was some gas spraying out from one of the lines. I got that tightened up but the engine runs with a very rough idle to the point of stalling. Having never done this before, is it possible I missed something in the process? For what it is worth, the rocker arm on the replacement pump has a slightly different shape even though it has the same universal number (40987). The new one is a CarQuest. Can't tell you what the other one was.
TAT_2
"17th Year" Silver Supporting Member, and Official CT Grim Reaper
TAT_2
Loc: "UNDER THE BOARDWALK"
Reg: 10-29-00
01-15-17 03:58 PM - Post#2671395
    In response to mikeag81
HOW WAS IT RUNNING B4 THE PUMP CHANGE ? DID A FEW BACK IN THE DAY ONLY BECAUSE THAY WERE LEAKING.I USUALLY BARED THE MOTOR OVER TILL THE ROD WAS ON THE FLAT SPOT OF THE CAM THEN INSTALL IT,SOME PUT A BOLT THRU THE SIDE OF THE BLOCK TO HOLD THE ROD.HERES A PIC OF THE ORG PUMP WITH A 360 VIEW ON THE SIDE.
https://www.amazon.com/ACDelco-40987-Origina l-Equi...
CAR QUEST PUMP
https://www.google.com/webhp?sourceid=chrome -insta...
PAGE DOWN FOR THE RARTS GEEK 1 WITH ANOTHER ARM VIEW
THE PUMP SHOULD PUT OUT ABOUT 6LB OF PRESSURE
09 PONTIAC- VIBE
08 PONTIAC- G6
96 FURD F-150 SUPER CAB XLT 4X4
NEXT ?
mikeag81
Loc: Western PA
Reg: 10-26-14
01-15-17 06:34 PM - Post#2671427
    In response to TAT_2
Before the replacement, starting and idle were fine. However, going up an incline, which is common here, there would almost always be a hesitation. I was going up a good sized incline when it finally gave out on me. It would not turn over at all while I was stuck on the side of the road, which made me first think it was a fuel problem.
YOUNG57
Loc: Tennessee
Reg: 12-06-10
01-15-17 10:26 PM - Post#2671474
If you had a gas leak on the pressure line side (fuel spraying out) you may also have a leak on the suction side. A leak on the suction side will break the vacuum and won’t draw fuel causing fuel starvation.
TAT_2
TAT_2
Reg: 10-29-00
01-16-17 07:04 AM - Post#2671516
    In response to YOUNG57
GOOD CALL,WITH OLDER CARS THE RUBBER FUEL LINES CRACK,SO CHECK EVERYTHING FROM THE TANK TO THE PUMP & THE PUMP TO THE CARB & FILTER,SOME PAPER FILTER'S IN THE CARB ALSO HAD A CHECK VALVE IN IT TO STOP DRAIN BACK.
09 PONTIAC- VIBE
08 PONTIAC- G6
NEXT ?
01-16-17 07:45 AM - Post#2671522
If you had fuel spraying out, the fuel pump is working. If there were a leak on the suction side, no fuel spray.
If you did nothing else to cause it to run rough, you could have excessive fuel pressure for your carb, overcoming the floats and flooding the engine.
Execution time: 0.432 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:47 PM
