Username Post: Pure Vs. Pre-mix anti freeze        (Topic#341821)
bigalturk1
Reg: 09-20-13
01-11-17 09:00 AM - Post#2670567
I graduated GM training center and Delco Remy school in the early 1970's. I remember one of my instructors (Mr. Walker) telling my class that the only time a vehicle should use 100% pure antifreeze (No water added) is in places like Alaska or Korea, during the winter months. He mentioned that 100% does not cool as well under ordinary circumstances (Back then there was no "Pre-mix", so it wasn't mentioned). Fast forward to later times I find that premix doesn't cool the engine on performance builds as well as using the non mix antifreeze (Mixed with water) does.
I do however like the idea that you can dump the premix on the ground w/o hurting the environment.
If a car gets hot in traffic and everything is in working order I just buy a smaller water pump pulley, it not only spins the pump faster but it also makes the alternator charge faster... although it does rob some Horsepower at the track.
thx1138v2
Reg: 05-01-14
01-12-17 04:42 AM - Post#2670692
    In response to bigalturk1
I ran into this info while looking for something else to do with cooling systems.
https://hellafunctional.com/?p=629
I combined the data from the two graphs into one graph. The numbers may not be exact because he didn't give the numbers but they are close.
Antifreeze Mixture
Edited by thx1138v2 on 01-12-17 04:45 AM. Reason for edit: No reason given.
scrambldcj8
Loc: MA
Reg: 04-06-03
01-12-17 05:26 PM - Post#2670809
The above two links pretty much counter Mr. Walker.
Also, I don't think any "pre-mix" can just be dumped on the ground without hurting the environment.....or pets for that matter. Although, there is environmentally safe anti-freeze mixes on the market...those can possibly be dumped?
454cid
454cid
Loc: West Michigan
Reg: 02-18-12
01-12-17 11:07 PM - Post#2670885
    In response to scrambldcj8
Yeah, pre-mix being "Safer" makes no sense to me either. It's my understanding that any of it does break down after awhile so I'm not super vigilant about not getting it on the ground. I'll catch what I can, and then rest I don't worry about. What I do worry about is any areas of fairly concentrated coolant, because of animals, so I'll wash that away with the hose.
99 K3500 RCLB
Execution time: 0.324 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 02:31 PM
