Username Post: door arm rest pads        (Topic#341820)
Gino
Loc: Pennsylvania
Reg: 02-11-03
01-11-17 08:27 AM - Post#2670559
I ordered two replacement arm rest for my 69 c20.
They were sold as the arm rest pads.
They appear as though there should be something behind them in order to mount them.
Since my truck did not have the arm rest in the fist place, I don't know if there was a metal bracket or something between the door and the arm rest pad or if they just screw to the door.
Any thoughts?
bobschevytrucks.com Ecklers
Andy4639
Loc: Liberty, SC
Reg: 08-06-16
01-11-17 05:01 PM - Post#2670622
    In response to Gino
Based on the 2 arm rest for the C-10 there is no bracket for them. The C-20 not so sure. Can you post pictures? That would help.
1956 Bel Air - LT-1/4l60
94 Elderado
2000 S-10
2008 LTZ Tahoe
2011 Treverse
JimKshortstep4x4
Chevytalk Moderator & "14th Year" Silver Supporting Member
JimKshortstep4x4
Loc: Muskegon, MI, USA
01-11-17 05:17 PM - Post#2670624
    In response to Gino
Does your door panels have the 2 holes located where the armrest would normally be? It sounds like your truck was not equipped for armrests.
The armrests were fastened to the door with two screws that went through punched holes in the door panel. The doors have should have two square holes to hold the 1/4-20 clip nuts which accept the screws.
You may want to pull the door panel to locate where to mount the armrest.
66 Impala SS, 396, TH 400
69 El Camino, 350, TH 350
Andy4639
Loc: Liberty, SC
Reg: 08-06-16
01-12-17 06:57 AM - Post#2670706
Here are a couple of pictures of my 71 door panels. These are stock arm rest. Two bolts hold them in place the arm rest has a metal backing on them.
Sorry drivers side isn't the greatest picture but you can see the holes for the arm rest. The door it self should have the nuts in place to hold it.
Attachment: DS_door_panel.JPG (36.74 KB) 12 View(s)
Drivers side.
Attachment: PS_door_panel.JPG (99.9 KB) 15 View(s)
Passenger side.
94 Elderado
2000 S-10
2008 LTZ Tahoe
2011 Treverse
Gino
Loc: Pennsylvania
Reg: 02-11-03
01-12-17 07:41 AM - Post#2670716
    In response to Andy4639
thanks, the pictures help.
I believe there is a template to drill the holes in the correct location.
My c20 did not have them in the first place but I wanted to be able to pull the door shut plus the arm rest is a small comfort item.
I plan on using the clips to secure the arm rest rather than just drilling a hole for the sheet metal screws that came with them.
Andy4639
Loc: Liberty, SC
Reg: 08-06-16
01-12-17 02:53 PM - Post#2670788
    In response to Gino
Mine are phillip head screws with nut inserts in the door.
94 Elderado
2000 S-10
2008 LTZ Tahoe
2011 Treverse
LUVmachine
Loc: Redding Ca
Reg: 10-02-14
01-14-17 02:18 PM - Post#2671164
My truck is the same way.
71 Chevelle BBC powered
2010 GMC Sierra crew cab 4X4
69_BOWTIE
Loc: WYOMING,USA
Reg: 02-27-02
01-16-17 08:50 AM - Post#2671534
    In response to LUVmachine
Mine are the same screws with inserts.
2001 Silverado 4X4
2005 FXDWGI
69 CHEVY Short Step
63 IMPALA 2/DR HRDTOP 327
Execution time: 0.566 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:03 AM
