Username Post: Evans Waterless Coolant        (Topic#341812)
mrunited
Reg: 01-08-10
01-10-17 11:17 AM - Post#2670447
I use Evans Waterless Coolant in my stock 55 Chevy 265! It doesn't cool as efficiently as 50/50 anti freeze, so it runs a little hotter, but it boils at 375f, so no over heating.
http://www.evanscoolant.com/
Tri5man
Tri5man
Loc: Possums Crotch, KY
Reg: 06-26-07
01-10-17 01:47 PM - Post#2670467
    In response to mrunited
I wouldn't waste my money on Snake Oil like Evans. A properly designed cooling system works just fine with 50/50 antifreeze/water combination.
Gary
TAT_2
"17th Year" Silver Supporting Member, and Official CT Grim Reaper
TAT_2
Loc: "UNDER THE BOARDWALK"
Reg: 10-29-00
01-12-17 09:12 AM - Post#2670735
DOWN ON THE FARM !!!
09 PONTIAC- VIBE
08 PONTIAC- G6
96 FURD F-150 SUPER CAB XLT 4X4
NEXT ?
42x
Loc: Davis, CA
Reg: 03-14-14
01-22-17 12:23 PM - Post#2672816
Evans actually works really well. Used it in my dirt bike (300KTM) for years and never had a over heating issue. It is used in the race boats down in Brazil since the ocean water temp was so high it could not cool the motors.
The down side to using Evans is if you get a leak you CANNOT add water to top off your system. Evans turns to jelly-o when water is added.
454cid
454cid
Loc: West Michigan
Reg: 02-18-12
01-22-17 12:56 PM - Post#2672829
    In response to 42x
That makes no sense to me. The ocean is much cooler than a radiator.
Weird, I wonder what it's made of.
99 K3500 RCLB
Donolie
Donolie
Loc: Detroit
Reg: 03-17-08
02-01-17 12:08 AM - Post#2674612
    In response to 454cid
No one mentioned the most important factor, it won't rust your engine cooling jackets. If you have a classic car, you may be worried about rust on something 30+ years old.
rod
Loc: kingman,az
Reg: 04-29-00
02-06-17 05:09 PM - Post#2675503
    In response to Donolie
Evans coolant is designed to run at a pressure greater than 20 lbs. which is very high and only new aluminuuuum rads can live with. also it needs a very high flow [50 gallons per minute+] water pump to help create pressure.
a 1955 stock rad will barley live at 7 lbs.
same goes for the pink RV type anti-freeze. freeze protection is good to 20 below straight. however it will not cool.
as said, go back to a clean system, good cap and stat and 50/50 [or less AF if your low temps allow]
Rod in AZ
Execution time: 0.19 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:12 PM
