Username Post: Need some measurements!        (Topic#341811)
the BossHogg
Reg: 03-08-14
01-10-17 09:46 AM - Post#2670437
Hi folks. I need some help please.
The hood hinges on my 50 Styleline were removed for painting the car, but their position wasn't marked! I'm now having a hard time aligning the hood and I hope some nice helpful person can give me a starting point by measuring where the hinges should sit.
Im thinking you could measure by putting one end of a piece of string/cord on the top bolt that holds the fender to the firewall, then measure to each of the hinge bolts?
Many thanks!
Mark
RAM_51
RAM_51
Loc: Yakima, WA. USA
Reg: 12-28-02
01-10-17 09:57 AM - Post#2670438
    In response to the BossHogg
Can't provide the measurement you want, but can direct you to the shop manual and the section that discusses hood alignment. Gap between hood and cowl should be approx. 3/16". See Installation in the second column. Click the link for a larger image.
LINK:
http://chevy.oldcarmanualproject.com/shop/1949_53/...
1951 Fleetline
Sheldon Y.
Loc: Waltham, Massachusetts
Reg: 10-29-16
01-10-17 05:04 PM - Post#2670492
    In response to RAM_51
My '49 is sitting in the garage with the hood up, but I don't understand how you want the measure?
'49 Styleline Deluxe Build@
https://www.jalopyjournal.com/forum/threads/49-sty...
http://www.frankenrodz.com/frankenstyle.html
the BossHogg
Reg: 03-08-14
01-11-17 02:31 PM - Post#2670598
That's perfect, thanks.
It sounds quite simple now!
Execution time: 0.319 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 02:17 PM
