Username Post: 12 volt conversion ?        (Topic#341801)
ck122
ck122
Loc: michigan
Reg: 12-28-12
01-09-17 07:32 PM - Post#2670363
I know you have to change all the bulbs and resistor for gas my ? what do you do to the voltage regulator on the fire wall do you remove it and if so what about the wires and what if there is no regulator ....yes it is a v 8 conversion in the works
its getting back on the road finally
Cruzin Okie
Cruzin Okie
Loc: Jay, Oklahoma
Reg: 10-26-11
01-09-17 07:54 PM - Post#2670368
    In response to ck122
ck122, try this link. If it doesn't work go to the sticky section and look for 6 to 12 conversion.
http://chevy.oldcarmanualproject.com/miscellaneous...
Bob does a great job on this issue.
Johnnie
1950 styleline deluxe sports coupe, 350 cid, TH 400, nova rear end. Gen IV Vintage air. SOLD!
1953 210 4 Door, 235 with Powerglide. All original except for the 1954 hood bird.
John 3:16
Edited by Cruzin Okie on 01-09-17 07:55 PM. Reason for edit: No reason given.
ck122
ck122
Loc: michigan
Reg: 12-28-12
01-09-17 08:06 PM - Post#2670370
    In response to Cruzin Okie
thank you just what I was looking for
Cruzin Okie
Cruzin Okie
Loc: Jay, Oklahoma
Reg: 10-26-11
01-09-17 08:10 PM - Post#2670372
Great!!! Good luck with your conversion.
Johnnie
John 3:16
01-09-17 10:00 PM - Post#2670389
It's easy once you read and understand what to do.
Cruzin Okie
Cruzin Okie
Loc: Jay, Oklahoma
Reg: 10-26-11
01-10-17 07:09 PM - Post#2670516
Yes it is. I have done a 6 to 12 volt conversion several times and it is pretty strait forward. Bob_Hayden did a really good job listing all the things needed along with instructions.
Johnnie
John 3:16
mtdriver
mtdriver
Loc: Billings, Montana
Reg: 02-04-15
01-11-17 12:22 AM - Post#2670540
Look up Eric's Projects on youtube
Life in the slow lane is a good life
Execution time: 0.3 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:54 AM
