Username Post: Need some advice        (Topic#341761)
Jack Crain
Loc: Wichita Falls, Texas
Reg: 07-24-11
01-07-17 03:15 PM - Post#2669898
I got caught out in the rain the other day and decided to get electric wipers and ditch the vacuum operated type. As with most of my adventures with the 46, I don't have a clue where to look or what to look for. Has anybody here swapped to electric and what do yall recommend?
1946 Fleetmaster 4-dr Sedan with '57 235
Fenton Dual Exhaust and Intake
Dual Carter Webbers 2 barrel Carbs
HEI ignition
Front Disk Brake
T-5 Tranny
Broo102
Broo102
Loc: RANCHO CUCAMONGA, CA.
Reg: 09-30-14
01-11-17 12:44 PM - Post#2670593
    In response to Jack Crain
Ive been looking for some also. I know that disassembly of the original chain from each transmission is impossible. So if you want to use your originals and they need to be re-chromed, they have to be done with everything intact, chain & all!
They have conversion kits where the motor fits on your originals from around $200. there was an article on the internet on a guy who did make his own bracket & bought a wiper motor for $20.
Sounds like a good project, Im guessing a lot of time.
Thanks!
Bru
John 3:16
32 Chev. 5 Win. Sports Coupe
Edited by Broo102 on 01-11-17 12:46 PM. Reason for edit: No reason given.
lofat46
2nd Year Silver Supporting Member
lofat46
Loc: Bloomingdale, IL
Reg: 08-12-13
01-12-17 06:25 AM - Post#2670710
Newport Engineering is a bolt-in replacement for the vacuum wipers. Connects up to all the stock mechanicals. I've had their 2-speed motor in my '46 for 15 years and never a problem. I believe they now have an motor with an intermittent setting. Specialty Power Windows has a cable operated system. A little harder to install but a friend with a '41 Chevy loves his. Both are a tad pricey but well worth the change.
www.newportwipers.com
www.specialtypowerwindows.com
1946 Chevy Fleetmaster 4-door Street Rod
Edited by lofat46 on 01-12-17 06:44 AM. Reason for edit: No reason given.
REBORN55
REBORN55
Loc: DeSoto, Illinois. 62924
Reg: 01-21-01
01-12-17 01:22 PM - Post#2670785
    In response to lofat46
I have had Newport in all but one of my 47-48 chevies. Have an extra complete setup with linkage and towers if any interest
Ken http://www.picturetrail.com/reborn55
Jack Crain
Reg: 07-24-11
06-09-17 06:19 AM - Post#2695190
    In response to REBORN55
Ok, I looked into the electric conversion and found out that I can't use my original A.M. radio if swapping over. So, that set me on the path of trying to get my vacuum wipers working better. Some of the ideas/suggestions were an accumulator in line with the vacuum hose, an electric vacuum pump to power the wipers, or changing out the mechanical fuel pump to one that a vacuum pump built in. All of the people I talked with had NO experience with vacuum wipers but each one thought they had the perfect fix. Any ideas on the suggestions? I was hoping to drive the 46 down to South Louisiana, but I will definitely need a good wiper system to drive there.
HEI ignition
Front Disk Brake
T-5 Tranny
06-09-17 10:13 AM - Post#2695211
I grew up with vacuum wipers, and would be the first to say that the technology definitely has its shortcomings. A conversion to electric would always be my first choice, but I haven't until today heard of a situation where this was incompatible with a factory radio.
If you must keep the vacuum system for whatever reason, the combination fuel/vacuum pump is a patch that offers only a minimal performance improvement. IMO, it's not good enough for a car which is to be regularly driven in the real world.
A standalone electric vacuum pump is a much better choice and would be my preferred solution if I had to keep the vacuum wipers. Now with that said, the electric pump is not a fix for a vacuum motor which is presently working less than optimally.
Do your wipers operate satisfactorily when the engine is idling? If yes, go ahead with the electric pump and you should be done. If no, then the vacuum motor must be overhauled and restored to as-new performance. A search will bring up specialty shops which offer this service. If you would rather DIY, parts kits with instructions are also available. Google is your friend here.
Jack Crain
Reg: 07-24-11
06-09-17 02:40 PM - Post#2695245
Ray, The size and location of the original radio is the problem. I have an original 5 tube radio that works and just for the " I've got a 70 year old radio that WORKS!" bragging rights, I'd like to keep it.
I've found a vacuum pump online, but all it says is it is for a Ford 250 and gives a range of years, but doesn't give the application, or the psi it pulls. Right now, at idle, I have a 18 psi vacuum and the wipers work great. The wiper motor itself looks to be recently overhauled, ie, nice and clean and "tight".
What do you think of the canister idea? Like maybe a gallon paint can?
HEI ignition
Front Disk Brake
T-5 Tranny
REBORN55
REBORN55
Reg: 01-21-01
06-09-17 07:35 PM - Post#2695278
Ford vacuum pumps that are belt driven like the one on the diesels usually pull around 21 inches of vacuum---some of the cars in the 70's used a can for a vacuum container--might try that
06-09-17 10:18 PM - Post#2695285
Canisters are fine for power brakes but useless for wipers because of the airflow volume through the vacuum motor. Remember, a PB booster doesn't flow anything. It is blind, just like the vacuum advance on a distributor.
Is the Ford pump electric or mechanically driven from the engine? If electric, is it 6V or 12V? I assume your car is still running on 6V if you have the stock radio.
Jack Crain
Reg: 07-24-11
06-10-17 03:08 AM - Post#2695308
It says 12 volt electric. The car was converted to 12 volts but I use a resister to get it down to 6 volts for the radio and heater motor
http://www.partsgeek.com/gbproducts/MC/5337-07 0174...
http://www.autozone.com/engine-management/vac uum-p...
HEI ignition
Front Disk Brake
T-5 Tranny
Edited by Jack Crain on 06-10-17 03:29 AM. Reason for edit: No reason given.
06-10-17 09:05 AM - Post#2695339
Jack, sorry to poop on your party, but the pumps you linked to appear to be for power brakes rather than wipers. Consequently, they could very likely have the same flow rate issue I mentioned earlier regarding canisters.
Jack Crain
Reg: 07-24-11
06-10-17 10:41 AM - Post#2695353
I just found that out. I got the one from AutoZone, hooked 12 volts to it and realized there was not the volume I needed. Took it back. Oh well, still looking!
HEI ignition
Front Disk Brake
T-5 Tranny
Edited by Jack Crain on 06-10-17 10:42 AM. Reason for edit: No reason given.
Jack Crain
Reg: 07-24-11
06-11-17 02:49 PM - Post#2695511
Scratch the canister idea, too. Didn't work. Looks like I'll either have working windshield wipers (electric) or a working original radio.
HEI ignition
Front Disk Brake
T-5 Tranny
Jack Crain
Reg: 07-24-11
06-12-17 03:11 PM - Post#2695701
Screw it, I'm going for the electric wipers. Seeing is better than listening
HEI ignition
Front Disk Brake
T-5 Tranny
06-12-17 10:31 PM - Post#2695747
Jack, how about one like this?
http://www.ebay.com/itm/Trico-Electro-Vac -Vacuum-P...
Not necessarily this particular one, of course. Ideally, you would find one which you know is in working condition. However, this is definitely the type of pump you want. It was made for vacuum wipers.
If you are more adventurous, you might want to consider one like this if you can devise a way to mount it and drive it from the engine. I presume the stock setup had some way of clutching it so it didn't have to run all the time. You could also drive it with a 12V motor.
http://www.ebay.com/itm/1937-1938-1939-19 40-Ford-M...
Jack Crain
Reg: 07-24-11
06-13-17 02:50 AM - Post#2695754
Ray, Those look like they would do the trick, all right. However, I am an impulse type of person and after the two "failures" I went ahead and removed the radio and ordered an electric wiper motor from Newport. I have a AM, FM, CD, Bluetooth, etc. do everything radio. I should be able to fit it in the existing radio hole with minor modifications. The old radio is self-contained, with built in speaker so I'll just hook up an antennae and a six volt power supply and use it in my shop.
HEI ignition
Front Disk Brake
T-5 Tranny
REBORN55
REBORN55
Reg: 01-21-01
06-13-17 07:03 AM - Post#2695785
Wish I had been quicker--have complete setup sitting on the shelf--newport wiper, switch---linkage and towers
Jack Crain
Reg: 07-24-11
06-14-17 04:18 AM - Post#2695882
Linkage and stuff are in good shape. Actually, the whole system looks to be in great shape but like I said, the vacuum design just don't quite cut it, no matter how good a shape it's in.
Hopefully, this will sort out my wiper problem then on to something else. Seems there is always something to do on the 46.
HEI ignition
Front Disk Brake
T-5 Tranny
Edited by Jack Crain on 06-14-17 04:20 AM. Reason for edit: No reason given.
Jack Crain
Reg: 07-24-11
06-19-17 03:36 AM - Post#2696489
I got the electric wiper motor in and am really happy with it. Keeps up the wiping speed no matter if I accelerate or not. I would put this mod right up there with disk brakes for safety.
HEI ignition
Front Disk Brake
T-5 Tranny
RoadRocker
RoadRocker
Loc: Kentucky.
Reg: 12-13-13
06-22-17 01:31 PM - Post#2697071
Sounds good Jack! I need them too! Tom
48 sports coupe
63 C-10 long fleet
13 Tacoma double cab longbed
17 Toyota Rav-4
Been down most all the roads nowhere left to go??
robhill
Loc: Oregon
Reg: 09-19-04
07-10-17 06:27 AM - Post#2699423
    In response to RoadRocker
Has anyone considered using a stepper motors, and driving them with a microcontroller? It would be easy to control speed and angle. Plus they are used in higher torque applications like as stage motor on CNC mills. Plus they don't take up tons of space. Might be ideal for this application.
https://www.youtube.com/watch?v=RakXequOrSY
https://www.amazon.com/dp/B012QFRKAO/ref=asc _df_B0...
1946 Chevrolet Fleetamster Town Sedan
Broo102
Broo102
Reg: 09-30-14
08-02-17 08:48 PM - Post#2702600
Did you see the article on an electric wiper motor swap for under $20? Its pretty good
Thanks!
Bru
John 3:16
Execution time: 0.249 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:36 AM
