Username Post: port holes in skirts?        (Topic#341711)
3rdelke
3rdelke
Reg: 12-06-16
01-05-17 02:21 PM - Post#2669501
not a question weather or not you like the look as I have kinda decided to install 53 buick in my skirts. problem is the car is already painted. anyone have a good idea how to cut oval holes? thx, bob
01-05-17 03:29 PM - Post#2669514
    In response to 3rdelke
How about using something like this:
Nibbler
Bel Air kiwi
Bel Air kiwi
Reg: 04-24-14
01-05-17 11:24 PM - Post#2669578
Hi Bob, Cool Idea. Couple of questions arise.
Have you already got your 53 ports, because looking at a primed body the original port holes have an elongated circular hole which would have been die cut in a gang punch which you simply won't find tooling for now.
The best device for cutting a round hole in an already painted flat panel is a chassis punch. They are actually radio chassis punches that were very common back in the day for non distorted round hole cutting. Google "Chassis punch" and images and you will see what I mean.
I have a concern that three oval ports would be too crowded on the space of a Bel Air skirt. Particularly given that they are bulky on the inside and may get too close to the wheel and the mounting structure to put them where they look right. Or if there is enough space in the back for it to work.
If I was going to steal your Idea, and that is very likely to happen, I would put three of the 51-52 Buick Roadmaster round ones with the flute and the wing. They are not so obviously Buick to the casual observer and super easy to install.
Cheers Kiwi
Bel Air kiwi
Bel Air kiwi
Reg: 04-24-14
01-05-17 11:39 PM - Post#2669580
    In response to Bel Air kiwi
Hi Bob, If you look at the back of the 53 type porthole there is a lot of depth that sits behind the outside surface. I went down and put my hand between the wheel and skirt and there just doesn't feel like there is enough space to give wheel clearance. Plus the lever lock would probably have to go so you would need to make the skirt lock in place some other way.
If I was to rate my chances of getting all the oval holes done right and the whole thing working without a fubar or scratching the paint. The honest answer is nil.
So when I steal your idea and do it on my Bel Air I am going to use the 51-2 Roadmaster ones. I like them because they whisper Buick and don't shout it. They are not as wide and so I will play around with the spacing a bit. When I finally mount them each one is just the little bolts from the inside, so no clearance issues and no large hole at all.
I can fubar it quite a bit and slot the holes and you will never see it. I bet I could do that without damaging the paint as well, but that is not a concern for me.
I would double sided tape them in place and eyeball a few different spacings and heights to get my final look then do a templated mount guide and drill the three small holes for each.
Funny thing is that the 51 style ones are cheaper and about ten times quicker and easier to mount using just handy man tools.
Cheers Kiwi
Attachment: 53_buick_port_hole_back.jpg (279.77 KB) 5 View(s)
Attachment: 51_52_roadmaster_porthole_front..jpg (24.62 KB) 7 View(s)
Attachment: 51_52_roadmaster_porthole_back..jpg (19.43 KB) 6 View(s)
Edited by Bel Air kiwi on 01-05-17 11:52 PM. Reason for edit: No reason given.
Dean50
Dean50
Loc: Detroit area
Reg: 01-02-07
01-06-17 09:21 AM - Post#2669644
Welcome to Chevy Talk.
Whichever ones you use, I think it will look sharp.
Dean50
3rdelke
3rdelke
Reg: 12-06-16
01-06-17 10:53 AM - Post#2669664
Kiwi, I have checked depth and should be enough clearance between brackets and wheel(late model posi). I really don't mind you stealing my idea cause the 52s look good but not quite as sexy as the oval 53s.thinking about carving out a two by six pine board to keep them solid and maybe a small circumference blade on a die grinder or angle grinder. then maybe a burr to clean them up.
3rdelke
3rdelke
Reg: 12-06-16
01-06-17 10:59 AM - Post#2669665
    In response to Dean50
thx, dean. hope it works, if not ill just repaint them. the paint is maybe 9 years old, but my brother never got it out of his garage, so it would be a descent match down low. its the new t bird color, pale green pearl
Bel Air kiwi
Bel Air kiwi
Reg: 04-24-14
01-06-17 06:39 PM - Post#2669747
Hi, Pale green pearl with clear coat looks stunning, google a car called "Kiwi Crush".
Matching old pearl colors is next to impossible as the pearl has to be flowed the same way to look even close to the same color.
Anything with pearl and iridescence needs to be painted as one, Light colors are worst.
Cheers Kiwi
01-06-17 11:05 PM - Post#2669783
Bel Air kiwi
Bel Air kiwi
Reg: 04-24-14
01-06-17 11:58 PM - Post#2669787
Hi Robert, Ha ha, this is what the real Kiwi Crush looks like.
Just out of interest, the fruit everybody calls "Kiwi" actually came from China and we engineered and faked them by branding them Kiwi.
Bet that's the first time it has happened that way around.
This is a US car and is one of the most refined and stunning Bel Airs I've seen
Cheers Kiwi
Attachment: bc650f2583ecf7be6274afa3ebcdbb97.jpg (78.79 KB) 7 View(s)
Edited by Bel Air kiwi on 01-07-17 12:27 AM. Reason for edit: No reason given.
Mike JW
Mike JW
Loc: Arroyo Grande, CA
Reg: 01-19-06
01-07-17 05:22 PM - Post#2669946
Good one RR I like it.
01-07-17 08:09 PM - Post#2669990
    In response to Mike JW
Thanks Mike.
But wow. That car is remarkable! Just gorgeous.
Bel Air kiwi
Bel Air kiwi
Reg: 04-24-14
01-07-17 11:08 PM - Post#2670017
Hi Robert, I thought you were "inserting the catheter" with the drink picture. (Taking the Piss).
That car was featured on the HAMB and it has a different approach to chopping the hardtop, which are challenging any way. Some would call this a mild custom but I just think it is superbly refined by someone with a real sense of what the car needs. About the only thing I would change is run it about 1-2" higher to make it easier to use as a vehicle. But that's preference not criticism.
It doesn't show in this picture very well but the roof and dash are a darker green and metal-flaked.
Cheers Kiwi
Edited by Bel Air kiwi on 01-07-17 11:09 PM. Reason for edit: No reason given.
Execution time: 0.321 seconds.   Total Queries: 18   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:29 AM
