Username Post: 62 235 into a 53 210 3spd. What's it take?        (Topic#341688)
Arominus
Reg: 01-05-17
01-05-17 12:22 AM - Post#2669378
I'm helping a friend with a 53 210 3spd that's got a rod knock. We have a line on a 62 235 for it and I'm trying to make sure I have the full story on what it will take to get the motor in with the minimum amount of effort.
I read on langdons that I need a custom engine mount? Where can I find this? What else do I look out for if we get the motor? I play with late 50s mopars so this I'm taking a crash course to help them out.
Bel Air kiwi
Bel Air kiwi
Reg: 04-24-14
01-05-17 01:05 AM - Post#2669380
    In response to Arominus
Hi Arominus. Welcome. the difference between the 52-4 ish motors and the later ones is the triangular bolt pattern for the side motor mounts is the same. So you need to rework the bottom of the mounting plates that holds the actual engine mount.
Also if the car is was 6V. You need to keep the early flywheel and clutch and starter and just change the solenoid to a 12V as the six and 12v systems don't have the same size flywheels or starter pinion, even though both pinions are 9 tooth they are different diameters. If car is still 6V don't bother but you need to spec the motor back to 6V. Coil generator etc.
These three pictures are of a fellow forum member's version who made new bottom halves based on the new engine, Matched them to the old top part and then finished them out to look factory
Cheers Kiwi
Attachment: IMG_3229.jpg (120.45 KB) 6 View(s)
Attachment: IMG_3227.jpg (63.35 KB) 1 View(s)
Attachment: IMG_3222.jpg (96.32 KB) 2 View(s)
Edited by Bel Air kiwi on 01-05-17 01:10 AM. Reason for edit: No reason given.
Bel Air kiwi
Bel Air kiwi
Reg: 04-24-14
01-05-17 01:09 AM - Post#2669381
    In response to Bel Air kiwi
Hi, these are the old mounts left and right, the line to make the first cut, and the block they came from.
Cheers Kiwi
Attachment: IMG_3219.jpg (81.78 KB) 1 View(s)
Attachment: IMG_3201.jpg (109.51 KB) 1 View(s)
Attachment: 1954-chevy-235-engine.jpg (36.15 KB) 2 View(s)
Bel Air kiwi
Bel Air kiwi
Reg: 04-24-14
01-05-17 01:19 AM - Post#2669382
Hi Again, this is the later block pattern. See how the mount three bolt pattern is upside down and a different shape triangle.
I am not sure who made these second ones and what you can buy or make yourself if you just want a simpler fix. IMO these need a side brace on at least one side of each bracket to stop them flexing continually.
The actual soft mounts and frame brackets are not modified with this type of conversion.
Cheers Kiwi
Attachment: 261_Long_motor_ex_truck__full_flow_filter_pin_position_58-62.jpg (357.92 KB) 3 View(s)
Attachment: 127228931_DexIKJbN_MM3.jpg (74.03 KB) 2 View(s)
Attachment: 127228930_g6HvHzk0_MM2.jpg (61.49 KB) 4 View(s)
Edited by Bel Air kiwi on 01-05-17 01:24 AM. Reason for edit: No reason given.
wbeaton
wbeaton
Loc: Hamilton, ON
Reg: 03-07-14
01-05-17 04:48 AM - Post#2669387
The 1962 engine will have the water pump mounted lower than the 1953. The fan will only blow on the bottom portion of the rad. Also the water pump shaft is longer and will contact the rad. To get around this, you can buy or make a short shaft water pump or use an adapter to install the 1953 pump on the 1962 motor.
The throttle linkage pivot is in a different location on the 1962. You will have to shorten the rod from the gas pedal to the pivot on the engine.
1951 Chevy Styleline Deluxe 2 Door Sedan
1954 235 with Isky Cam, Shaved Head
Dual Carter YF 787S Carbs on Offenhauser Intake
Split Manifold Dual Exhaust
3 Speed with 3.55 Differential
12V Conversion with Alternator
Pertronix Ignition
Arominus
Reg: 01-05-17
01-05-17 07:56 AM - Post#2669402
    In response to wbeaton
Is it worth the effort to put the 62 motor in vs rebuilding the 53 splash oiler? The 62 is $800 with a trans and we then have to make it work, obviously we don't need that trans that comes with the 62.
Any one have a link to the water pump adapter?
wbeaton
wbeaton
Loc: Hamilton, ON
Reg: 03-07-14
01-05-17 08:24 AM - Post#2669409
I think the 62 is a worth while improvement. $800 does seem a little steep.
http://www.ebay.ca/itm/1955-1962-CHEVROLE T-235-261...
Pertronix Ignition
Edited by wbeaton on 01-05-17 08:25 AM. Reason for edit: No reason given.
Arominus
Reg: 01-05-17
01-05-17 08:41 AM - Post#2669415
Ill see if we can get it without the Trans for less if they go that way.
The motor has a lot of chrome on it and was just running (v8 swap in the truck it was in i think). It also has the "good" 848 head? thats what butch said over on the HAMB.
Thank you for the link!
wbeaton
wbeaton
Loc: Hamilton, ON
Reg: 03-07-14
01-05-17 08:56 AM - Post#2669418
After 1956, they all had the 848 head. There is value in a known good running engine. Speed parts would also increase the value.
Pertronix Ignition
Edited by wbeaton on 01-05-17 08:57 AM. Reason for edit: No reason given.
01-05-17 09:03 AM - Post#2669420
Is the 62 out of a car or truck?
The 53 uses a front mount under the crank pulley. The 62 can be drilled to use the front mounting.
wbeaton
wbeaton
Loc: Hamilton, ON
Reg: 03-07-14
01-05-17 09:27 AM - Post#2669425
1953 has side mounts. 1949-51 has the front mount. I don't know if the 1953-54 front cross member has the provision for front mounts.
Pertronix Ignition
01-05-17 09:40 AM - Post#2669429
I'll own 'em. I fabricated these. This might be the first set I made which I later discarded because they put the motor too high in the engine compartment. The second set does have braces.
Arominus
Reg: 01-05-17
01-05-17 10:11 AM - Post#2669437
The 62 was in a truck
01-05-17 01:44 PM - Post#2669482
If for some reason you don't want to fab new engine brackets, commercial swap brackets are finally available. These might be a fairly recent development, because they weren't on this site the last time I looked. They could be the same parts which rrausch is talking about, as they appear to match his description.
http://www.ebay.com/itm/10061-1952-54-CHE VY-CAR-w-...
I agree with wbeaton that the 62 engine is definitely a worthwhile improvement over the 53. If you don't want or need the chrome, you can probably sell it to recover part of the cost.
01-05-17 04:33 PM - Post#2669515
mine are prettier.
KaelFarmer
Loc: Eau Claire, WI
01-05-17 05:28 PM - Post#2669530
I agree that $800 may be a bit steep. Where are you located? Other members might have an idea of another engine available.
Kael
01-05-17 06:28 PM - Post#2669536
  • rrausch Said:
mine are prettier.
Oh, I agree, but not everyone has the skills you do. The commercial parts just offer a solution for those who are not as well endowed.
Arominus
Reg: 01-05-17
01-05-17 07:12 PM - Post#2669548
    In response to KaelFarmer
We are in on the front range in colorado. I have pictures of the engine, but I don't see a way to attach them to my post. Do we have to host offsite?
There is also a 57 235 for sale for 500 but I really don't think it's as good as the 62 wear/care wise. The 62 is nice and clean and looks to have been decently cared for.
Mike JW
Mike JW
Loc: Arroyo Grande, CA
Reg: 01-19-06
01-05-17 07:48 PM - Post#2669553
Watch out for that Raddle Can Rebuild. Looks don't mean much when it comes to motors.
Bel Air kiwi
Bel Air kiwi
Reg: 04-24-14
01-05-17 10:34 PM - Post#2669569
    In response to Mike JW
Hi Guys, thanks for adding in the fan and water pump stuff I forgot. As folks are saying the later engine is better but you need to get a good runner and check out compression, cylinder load, oil pressure, temp stability etc.
I haven't had an early engine rebuilt but I would imagine if you got a quality specialist to redo the entire motor top to bottom then you would spend say $3000 and it will need a partial redo in 50,000 miles aprox.
If you get a good running later one and use an oil filter, service it regularly, don't let it get hot or run lean then you may get 30 to 50,000 out of that.
Chevy got better at making those engines far more reliable and long lasting, having made millions of them over more than a decade. They just never tried to make them light, fast, or economical. LOL
So the later the engine in the series the more advances and fixes it has had built in.
If you become a silver supporting member then you can up load Pics direct and you have joined our community in a committed way so the willingness of other to help will match your commitment I am sure. There is an enormous resource here and most of our venerable elder members have forgotten more about your car than you will ever need to know.
Cheers Kiwi
Bel Air kiwi
Bel Air kiwi
Reg: 04-24-14
01-05-17 10:47 PM - Post#2669570
Hi Robert, Happy New Year, OK so you put your head up over the trenches and called your's prettier.
I'll take the bet and call you on that.
How about these then, that are not even fully dressed and they look like they are a factory part. Half an hour on the linisher and you could not even tell they weren't OE.
So photo's or fold pardner.
Cheers Kiwi
Attachment: IMG_3237.jpg (105.75 KB) 1 View(s)
Attachment: IMG_3240.jpg (117.35 KB) 2 View(s)
Bel Air kiwi
Bel Air kiwi
Reg: 04-24-14
01-05-17 11:01 PM - Post#2669571
HI Ray, When I do my 261 into the Bel Air I'll buy some of those; and I will use them as a height guide and check with new soft mounts. Take them off and use them as a jig to do what this guy has done to the factory parts to make it look stock. Then sell the aftermarket ones.
That will save me at least half a day if not more battling away in the bay to get the motor pattern hole part made and the motor position right.
If I then threw them in the bin I would still be way ahead on time v dollars. But I will get most of my money back and all the makers engineering time and effort prototyping and verifying them for near free.
I would never make or sell them to anyone else. That's fraud.
Hi Arominus, you are never going to make a set of these like those ones Ray found for you for anything like the price they sell at. So unless you want to work for three to five days or more to make something like them or more OE looking you are wasting your time. Some of us love to do just that and have even made a career out of it. There isn't a dollar in reinventing the wheel so unless your time and skill are of no value, buy some.
Cheers Kiwi
Edited by Bel Air kiwi on 01-05-17 11:15 PM. Reason for edit: No reason given.
01-06-17 09:37 AM - Post#2669634
  • Bel Air kiwi Said:
Hi Robert, Happy New Year, OK so you put your head up over the trenches and called your's prettier. I'll take the bet and call you on that................
Cheers Kiwi
What are you betting on? I don't understand your Kiwi-ese sometimes. Are you saying you don't think I really fabricated those? Well, I did.
Here's another set I did. I'm not sure right now which set was the first set (unbraced) and which is the second set that were later braced, but my first set positioned the engine too high and I couldn't get the cast aluminum valve cover off as the back wouldn't clear the firewall at the top of the cove. I believe this set I made out of 4X6 angle iron, but the other set I just had bent at 90 degrees at a friend's machine shop.
01-06-17 09:35 PM - Post#2669763
Darn it, I keep forgetting about those side mounts.
01-06-17 10:21 PM - Post#2669770
Pulled out a front mount I have. Took pictures of it. It must be from the parts department as it has holes for a car and a truck when it is a front mount. When they went to the side mounts these didn't have any holes.
Attachment: Front_Mount_2_-_Copy.jpg (175.88 KB) 2 View(s)
Attachment: Front_Mount_3_-_Copy.jpg (273.31 KB) 1 View(s)
Bel Air kiwi
Bel Air kiwi
Reg: 04-24-14
01-06-17 10:31 PM - Post#2669773
Hi Robert, I was joking with you because I know you made them. If you still have the pattern you could make a pair for me! I think the other poster who made the ones from original tops probably took three or four days each to make them look like stock parts. That appeals to me because I used to do that for a job so it has become my aesthetic for parts. It is prohibitively expensive for one off work but that's not my background.
I like the idea that 99% of car people won't pick his change when done and to me that is cool.
I made an alternator bracket for my Cleveland engine that held a Toyota Alternator on the original fuel pump mounting studs. Started out as a piece of angle iron just like you did. 10 hours of cutting filling and linishing you couldn't tell.
Cheers Kiwi
Bel Air kiwi
Bel Air kiwi
Reg: 04-24-14
01-06-17 10:37 PM - Post#2669774
Hi Keith, That's a tilted over engine style one. Maybe was in a bus or something? Could it be from a GMC school bus or maybe some type of cab-over truck?
That would be quite rare now.
Cheers kiwi
Edited by Bel Air kiwi on 01-06-17 10:39 PM. Reason for edit: No reason given.
01-07-17 11:14 AM - Post#2669839
Thanks Kiwi. I'd make you a set but it's 2 degrees F this morning and the barn is unheated.
Coupe50
Coupe50
Loc: Sweden
Reg: 04-27-14
01-14-17 01:03 AM - Post#2671084
Just a quick question on this subject. I have a -62 engine in my -50 Coupe and i use the original engine mounts. Is it ok? I just have the engine renovated (right word??)so i dont want to have any problem when i put it back in the car. Carla.
Bel Air kiwi
Bel Air kiwi
Reg: 04-24-14
01-14-17 01:12 AM - Post#2671085
    In response to Coupe50
Hi Carla, No problem to use a front mount with a later engine, Somebody must have done the change already. Make sure your two mounts at the rear of the motor are in good condition. There are lots of styles of mount which depends on the year of the vehicle and the year of the motor. Up to 52 all were front mount. 52-54 were an unusual tower type side mount. 55 On were a regular side mount but the pattern on the block was different.
The combination we have been discussing is a 51-4 car with a 55 or later motor.
I am not 100% if 55 was the motor change but if its 58- on it definitely is.
We would say rebuilt or reconditioned, but we know what you mean.
Cheers Kiwi
Edited by Bel Air kiwi on 01-14-17 01:25 AM. Reason for edit: No reason given.
Execution time: 1.323 seconds.   Total Queries: 21   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:03 PM
