Username Post: damage upper grill        (Topic#341677)
space66
space66
Loc: montreal
Reg: 06-01-16
01-04-17 11:36 AM - Post#2669307
hey all,
i got my original upper grill damaged in a hit & run...any one tried ,is it possible to make a repair and is it worth it? it's dented and cracked on the right wide section. i will have to drill out the old rivets to get it out, so do they make replacement rivets, part#? and where can i get them.thanks
upload gifs
1966 impala convertible 283*pg-396*th350
Oshawa65SS
Loc: Burnaby BC Canada
Reg: 09-22-14
01-04-17 06:05 PM - Post#2669346
    In response to space66
Sorry to hear that news.
If the rivet part numbers are called out in the assembly manual, then you could look up that number in the amk products pdf glossary to see if they have a number for it.
At any rate, you'll want an all aluminum rivet for ease of installation.
Here's a vid about aluminum trim repair:
https://www.youtube.com/watch?v=4t8n9dTLFEQ
They have quite a few different videos.
Good luck, too much of an artful skill for me.
Ryan
65 Impala SS convertible 283 2V with Powerglide and 10 bolt 3.08 open
Build date Dec. 21 '64 Oshawa
bigbowtielover
bigbowtielover
Loc: Surrey British Columbia
Reg: 09-01-13
01-04-17 09:55 PM - Post#2669369
The grill is bright dip anodized. You can't fix it without stripping off the anodizing first and then after repairing it will have to be polished and sent out for bright dip anodizing (good luck finding a place that actually DOES bright dip) or it can be clear coated or chromed. Or try to find a good used replacement. The reproduction lower grill pieces are chromed aluminum. Not sure if an actual upper grill is available yet.
space66
space66
Loc: montreal
Reg: 06-01-16
01-05-17 08:32 AM - Post#2669412
    In response to Oshawa65SS
thank Ryan.
i'll do some more research on the repair.
i got a spare grill, but will need some work on the pitting and polishing
space66
space66
Loc: montreal
Reg: 06-01-16
01-05-17 09:25 AM - Post#2669424
    In response to bigbowtielover
i don't think there's many available, you have them all...loll
http://www.classicindustries.com/product/impala/pa...
http://www.althafastener.com/62-63-64-65-66-67-68- ...
http://www.ebay.ca/itm/NOS-1966-67-68-CHE VY-IMPALA...
is the original Grill in stainless steel or aluminium ? looks like white metal..
thanks.
Oshawa65SS
Reg: 09-22-14
01-05-17 08:33 PM - Post#2669561
These aren't the original rivets are they?
I'm hoping they're just some service replacement distant cousin of the assembly line version.
PITA tool required to install these.
This is the same type of rivet that secures the clamp to the frame for the positive battery cable.
http://www.ebay.com/itm/NOS-1966-67-68-CH EVY-IMPAL...
The original grill is aluminum, but I've seen stainless steel custom grills that are very nice for a restomod car on ebay on occasion.
Nothing right now though.
Ryan
fsc66
Loc:
Reg: 05-05-12
01-05-17 11:06 PM - Post#2669572
That Grille on Classics website has been there for years and it never has been available.
Paul
space66
space66
Loc: montreal
Reg: 06-01-16
01-06-17 12:29 AM - Post#2669579
yes they are. p/n 3855120 as per manual.
here's AMK product
https://www.amkproducts.com/bulk3.asp?part=B-13399
aawtech
Loc: Bellmawr, NJ
Reg: 09-11-06
01-06-17 07:17 AM - Post#2669607
  • space66 Said:
hey all,
upload gifs
I have a completely restored upper, lower, and H/L bezels that have been re-anodized as original and completely detail painted ready to install. If you're interested, send me a private message and I'll get you some photos and pricing. Can't do that here in the forums.
Donny
space66
space66
Loc: montreal
Reg: 06-01-16
01-06-17 09:31 AM - Post#2669633
    In response to aawtech
thanks Donny. but i already have a spare original one if needed.this one here is in perfect shape apart the dent so will repair it.
SSImpala327
Loc: Damascus, MD
Reg: 06-14-13
01-07-17 02:13 PM - Post#2669874
You can replace them with nuts and bolts. They sell them specifically to replace the rivets.
1966 Impala SS 327 Ermine White
2006 Dodge Charger Top Banana Daytona
aawtech
Loc: Bellmawr, NJ
Reg: 09-11-06
01-07-17 05:34 PM - Post#2669922
There are two folks I can recommend for you. Last one I had done was about 550-600 to give you an idea.
Donny
Execution time: 0.353 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:47 AM
