Username Post: Mounting/installing the front bench seat.        (Topic#341186)
ptjsk
ptjsk
Loc: Northern California
Reg: 05-30-08
12-11-16 12:31 PM - Post#2665576
Hey Guys,
I'm obtaining a test fit of the front bench seat for the '55 Nomad.
I have the brackets that install over the front rails of the slide bracket, but the rear mounting locations are not in line with the holes that are in the floor. Is there another type of bracket that the rear of the slide mounts to, or is it supposed to mount directly to the floor?
Thanks, Pat
swbatt
West Coast Show Support
swbatt
Reg: 03-25-01
12-11-16 03:42 PM - Post#2665597
    In response to ptjsk
My car (sedan delivery) came with a factory bucket seat, but someone had installed a bench before I got it. The rear bracket just sits on the floor.
Nomad Jack
Nomad Jack
Loc: Cape Cod, Ma.
Reg: 03-14-03
12-12-16 06:50 AM - Post#2665688
The rear bolts directly to the floor and the front has the "hat" bracket you described.
Nomad Jack
55 Nomad
http://www.jaxcars.net/55-chevy-nomad.html
57 3100 Pick-up
http://www.jaxcars.net/57-chevy-pick-up.html
31 LT Truck
http://www.jaxcars.net/31-chevy-truck.html
gundog55
gundog55
Loc: Northern Indiana
Reg: 09-26-11
12-12-16 11:32 AM - Post#2665734
    In response to Nomad Jack
The front bracket can be mounted in either direction. One way locates seat in stock location, the other way moves the seat back about 2 " or so.
1955 Two Door Post,400 SBC, 400 Turbo, Dana 60 W/456 Gears. 1955 Nomad, 355 SBC, 400 Turbo, 12 Bolt W/410 Gears.
DRIVE IT LIKE YOU STOLE IT!
57tim
57tim
Loc: Cameron, Wi, USA
Reg: 11-09-01
12-13-16 11:05 AM - Post#2665903
    In response to gundog55
??????? All four holes are in the floor and there is no adjustment for moving the seat back 2".
57 Bel Air 2dr Ht
327 700r4
12-13-16 05:59 PM - Post#2665988
    In response to 57tim
He is saying that if you flip the bracket around it mounts the seat on the bracket further back, not that there is another set of holes in the floor.
57belairman
57belairman
Loc: Missouri City Texas USA
Reg: 03-16-02
12-21-16 04:03 PM - Post#2667171
    In response to wagonman100
What about the holes at the rear of the seat. Those are fixed.
Life is short, Eat dessert first, I always do!!
Picturetrail
57 2dr ht red
57 Convertible black
57 Nomad larkspur blue
57 3100 Pickup
55 2dr Sedan
56 Suburban
ptjsk
ptjsk
Reg: 05-30-08
12-22-16 06:29 AM - Post#2667254
    In response to 57belairman
The bottom of my seat says it's a '55 hardtop seat. But the rails for the seat are sure don't appear to be original as they are about 1.5" too long to mount to the original bolt pattern.
I ended up just fabricating some mounting plates and they turned out darn good. Plus my shifter now has plenty of room without hitting the seat.
Thanks for the responses,
Pat
swbatt
swbatt
Reg: 03-25-01
12-22-16 07:53 AM - Post#2667268
If the seat went back 2 more inches, I think it would hit the rear seat when in the down position?
ptjsk
ptjsk
Reg: 05-30-08
12-22-16 12:25 PM - Post#2667297
    In response to swbatt
Man, I hope that's not going to be an issue.
The slide does have good adjustment on it, so hopefully it will slide up far enough as to clear any potential issues.
Pat
Edited by ptjsk on 12-22-16 12:25 PM. Reason for edit: No reason given.
nomads
Execution time: 0.244 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:54 AM
