Username Post: Restoring a '47 Fleetmaster        (Topic#341143)
vj1277
Loc: Bronx, NY
Reg: 12-09-16
12-09-16 07:42 AM - Post#2665277
Hi! This is first post on this forum.
I recently bought a 1947 Fleetmaster 2-Door and it's my first restore-no motor or transmission-it's just a shell. I'm looking to replace the suspension and put a V8 in it. I've been considering an C4 suspension and a 350/TH350 combo.
Right now I'm dismantling the car for bodywork, but looking for advice and guidance on how to proceed mechanically.
Should I get a Heidts Superride suspension? Or TCI? What about a C4 suspension?
I'm looking for a great recipe for a daily driver, but also to do things affordably.
12-09-16 09:52 AM - Post#2665298
    In response to vj1277
Welcome aboard VJ.
Love those long hoods. Sounds like you'll have your hands full.
12-10-16 08:56 AM - Post#2665415
Welcome to ChevyTalk. Check this sticky in the 49-54 forum THE DEAD HORSE: V8 SWAPPING. Not all of it pertains to our years, but it has a lot of info. We have several guys that have went to V8s. I did one into a 48 in 1967 using the engine, trans and rearend from a 56. It is long gone tho.
vj1277
Loc: Bronx, NY
Reg: 12-09-16
12-11-16 08:18 PM - Post#2665657
Thanks for the info. I'll check it out!
lofat46
2nd Year Silver Supporting Member
lofat46
Loc: Bloomingdale, IL
Reg: 08-12-13
12-13-16 06:37 AM - Post#2665870
Welcome to the forum VJ, you'll find a lot of help and information here as you progress through your project. As far as your suspension choices I would have to put my two cents worth in for the Chassis Engineering bolt in components. Unbolt your old stuff and the new stuff bolts into the same holes plus a few more you have to drill. No welding, good handling and ride. They have everything you need for front and rear suspensions, motor and trans mounts and more.
www.chassisengineeringinc.com
1946 Chevy Fleetmaster 4-door Street Rod
Edited by lofat46 on 12-13-16 06:38 AM. Reason for edit: No reason given.
vj1277
Loc: Bronx, NY
Reg: 12-09-16
12-21-16 08:19 AM - Post#2667084
    In response to lofat46
Thanks for the advice on Chassis Engineering.
I bought an 84 Corvette mainly for the IFS, engine and transmission. I called CE yesterday, and they don't have a kit that works with the Corvette IFS (it's Mustang II). That leaves Flat-Out Engineering and Progressive Automotive with C4 kits I can use.
Broo102
Broo102
Loc: RANCHO CUCAMONGA, CA.
Reg: 09-30-14
01-08-17 07:18 PM - Post#2670194
Use an over drive Trans like 2004R or 700R4 for better gas mileage. I installed a V8 in a convertible, a lot harder than the hard tops, but it was interesting!
Thanks!
Bru
John 3:16
32 Chev. 5 Win. Sports Coupe
Edited by Broo102 on 01-08-17 07:25 PM. Reason for edit: No reason given.
vj1277
Loc: Bronx, NY
Reg: 12-09-16
05-31-17 12:32 PM - Post#2693710
What's your advice on engine and drivetrain? I've been told that getting a 5.3l Chevy Tahoe or Silverado (post 2000) is great because it's LS-based and easy to install.
lofat46
lofat46
Reg: 08-12-13
06-01-17 06:27 AM - Post#2693837
LS motors are the hot setup right now. It's not a Chevy but a friend just put and LS engine with a 4L60E overdrive trans in his '38 Buick coupe. Runs great. Harnesses are available from a variety of after market sources.
Edited by lofat46 on 06-01-17 06:29 AM. Reason for edit: No reason given.
vj1277
Loc: Bronx, NY
Reg: 12-09-16
06-06-17 05:43 AM - Post#2694669
Thanks for the note. LS it is!
Execution time: 0.184 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:40 AM
