Username Post: Is 14.4 volts to much coming out of alt.        (Topic#340650)
Nicksd
Reg: 09-02-09
11-16-16 08:51 AM - Post#2661849
I have a 1955 Chevy with a 700r4 trans. and 350 motor. I put on a single wire alt. Now I noticed that I'm pulling 14.4 volts upon exceleration. Is this to much? I also noticed that at night my rear running lights go out and brake lights go out. I'm wondering if my light switch is acting like a voltage req. and when the voltage gets to high it opens the circuit. 55 chevy light switches have that protection in it.
57tim
57tim
Loc: Cameron, Wi, USA
Reg: 11-09-01
11-16-16 10:18 AM - Post#2661866
    In response to Nicksd
14.4 volts is the correct voltage. You have something else wrong in your light circuit I believe.
57 Bel Air 2dr Ht
327 700r4
11-17-16 01:36 AM - Post#2661972
Are you running headlights which draw more current than stock?
11-17-16 07:04 AM - Post#2661994
Ray, check the stock forum. We got more key information.
11-17-16 08:58 AM - Post#2662006
    In response to acardon
Nick's post was apparently deleated from the stock forum after I responded to his new information.
Nick, the gray and white wires are on the wrong terminals of the headlight switch. The gray wire is being shorted out when the switch is bolted to the dash. Link to light switch.
4dr 57
4dr 57
Loc: Texas Hill Country
Reg: 11-10-04
11-20-16 08:29 AM - Post#2662383
I'll thank you for the OP.
GREAT CALL acardon! Thanks a lot!
It's all good. mostly
Execution time: 0.635 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:05 PM
