Username Post: Overheating        (Topic#340547)
Jasonda
Reg: 07-07-13
11-12-16 04:10 PM - Post#2661217
I am sure this has been covered before but here it goes. We have an early 70's 350, it was a complete rebuild and dyno tested at 425 hp. Cannot find who rebuilt it do to a death. Our problem is overheating. Builds enough pressure to blow the upper hose off. Temp gauge is new and goes from 180 -240. New water pump, tstat 160, aluminum rad. Heads off and look ok, head gaskets fine.
I see in the middle of the heads is a water port but not one in the block.
Any help would be great
11-20-16 12:26 AM - Post#2662342
    In response to Jasonda
how fast does it get hot? is there flow through the rad? what is the temp differential from inlet and outlet of rad? electric fan? pics?
11-20-16 06:03 AM - Post#2662364
    In response to bobb
Right rotation water pump?
11-20-16 08:08 AM - Post#2662381
If it's blowing the hose off, the radiator cap is defective or the hose is incorrectly installed. A hose WILL NOT blow off at 16 psi. With the right amount of antifreeze and a good cap, coolent should not boil at 240 degrees.
Execution time: 0.576 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:20 PM
