Username Post: 1999 camaro coil pack not firing?        (Topic#339007)
Tony UK
Tony UK
Loc: Birmingham UK
Reg: 09-12-16
09-12-16 04:30 AM - Post#2650760
[Hi, I have a 99 european spec v6 3.8 DIS Camaro which has recently developed a misfire on examination it seems one coil pack is failing to fire. changed out this coil and swopped them around but the third coil always fails to fire. I know all 3 coils are good. Any ideas would be welcome. no American car service centres here!!b]
77chevy
77chevy
Loc: trusting earth to a boys ...
Reg: 01-26-01
09-15-16 05:05 PM - Post#2651562
    In response to Tony UK
dont know if you got it solved. If not check for 12 volts under the coil, if no volts check the ignition control module or crank position sensor (not likely tho).
Tony UK
Tony UK
Loc: Birmingham UK
Reg: 09-12-16
09-17-16 07:58 AM - Post#2651809
    In response to 77chevy
Thanks for reply, in process of obtaining ICM as soon as I can find one here, or worst case get one shipped from USA
77chevy
77chevy
Reg: 01-26-01
09-17-16 06:03 PM - Post#2651880
did you not have 12 volts?
hope you can get your hands in one if thats the problem. it must be like us in US trying to get a real mini cooper.
Execution time: 0.272 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:02 AM
