Join the Community today
Username Post: Dual Carter set up        (Topic#338482)
Pmullins61
Pmullins61
Loc: Frankfurt, Germany
Reg: 04-17-16
08-22-16 07:57 AM - Post#2647024
I have installed dual Carter carburetor set up on my 1950 216,
From cold the car is running great starts first time with the automatic choke.
When I stop switch off the engine and then re start before the engine is cold it smokes a bit and runs a bit lumpy like the choke is open, as these are really maintainence free not sure what the problem could be, interested if anyone had a similar problem.
Seen a lot of members have installed their fuel filters on the carb side of the engine is this important
As always appreciate the feed back
Bel Air kiwi
Bel Air kiwi
Reg: 04-24-14
08-23-16 03:43 AM - Post#2647151
    In response to Pmullins61
Hi PMullins, I like the filter before the fuel pump to protect it as well. If you put them on the manifold side, and many do, a leak could mean a fire. Not on the other side.
What color smoke? If Black then over rich, ergo too much choke. Some Auto chokes are adjustable.
Cheers Kiwi
Edited by Bel Air kiwi on 08-23-16 03:43 AM. Reason for edit: No reason given.
Pmullins61
Pmullins61
Reg: 04-17-16
08-23-16 08:27 AM - Post#2647202
    In response to Bel Air kiwi
Thanks buddy, currently the filter is on the distributor side, I leave it where is is, I think you are right with the choke needs a bit of tinkering and technique when starting after a run or I sit have another coffee wait for it to get cold then drive it, nothing serious, someone did mention the vacuum
Pmullins61
Pmullins61
Reg: 04-17-16
08-25-16 01:02 AM - Post#2647551
Well it's not the chokes, checked these today
Getting some grey smoke when ticking over, still lumpy after rear start, think it could be the fuel pump delivery to much fuel at idle
Pmullins61
Pmullins61
Reg: 04-17-16
08-25-16 09:36 AM - Post#2647609
Cleaned the carbs today and tried starting the car without touching the gas pedal, run it for 60k and then re started after 30 mins and did another 5k, running smooth as
Attachment: image.jpeg (186.11 KB) 50 View(s)
Attachment: image.jpeg (1.61 MB) 45 View(s)
Pmullins61
Pmullins61
Reg: 04-17-16
08-25-16 09:37 AM - Post#2647610
Many thanks for all the advice
08-25-16 07:44 PM - Post#2647718
Nice looking Fleetline.
Pmullins61
Pmullins61
Reg: 04-17-16
08-26-16 11:48 AM - Post#2647817
Thanks Keith
Rustchips
Rustchips
Loc: DFW Texas
Reg: 02-24-05
09-18-16 10:50 AM - Post#2652002
Sweet!
Cleon
1928 Chevy Coupe
1955 Chevy Bel Air HTP
1970 El Camino
1990 F##d Mustang Convertible
chronamyd
Loc: Nanoose Bay BC Canada
Reg: 05-02-12
01-05-18 01:23 PM - Post#2720134
    In response to Rustchips
I am restoring a 54 150 bus. Coupe, I am putting in a 261 from a 55 pickup. I was thinking of going with the duel 2 brl Webbers from Clifford’s performance. Can I get some feedback on this carb set up. It is supposed to give better performance and milage and I think it is water heated. I am using headman headers thanks Dwight
Bel Air kiwi
Bel Air kiwi
Reg: 04-24-14
01-09-18 05:18 PM - Post#2720606
    In response to chronamyd
Hi Dwight. The sort of carburettion that suits your engine is dependent on what spec your 261 engine has.
If it is dead stock 261 it would normally have had a very slightly larger cam and carb than a 235, as built.
There are two things adding twin carbs can achieve.
The first is better fuel balance or distribution between the cylinders. The second is it is a way to supply more fuel to the engine but maintain low end responsiveness.
So you need to think about which you want as you almost always get the first but you may not need the second.
This is where you need to go to school on your engine and find out exactly what you have. Find out what head it has on it, what cam spec (Some 261's have the Vette cam.) etc.
Your engine may be specified for around 125 HP but may be up to 150- ish. So you need to work that out. Modern fuels will allow the use of a higher static compression ratio and if you plan this, some cam, and some porting this will change the carb sizing/jetting.
If it is staying stock and you want old school appearance then two old carters from 216" rebuilt as a pair would be good. Two old 235 Rochester's would be in my view a bit much for road use, as they are larger. But that is how the manifolds are supplied.
The modern Carter two barrels are actually a Weber design and a very good design. Because they are a two barrel progressive they are very sensitive however the manifolds require an adapter to fit them. personally I would like to see the manifold patterns updated so they actual bolt on directly as this would be nicer, but that's volume economics.
Be aware that the 261 has a different head and gasket from the near identical 235 and it must have the extra water passages to be viable.
Some folks call these "steam holes", but steam and destruction is what you get if they don't have them.
How much you need manifold heating depends entirely on your driving needs and climate but it is usually required.
Cheers Kiwi
Edited by Bel Air kiwi on 01-09-18 05:40 PM. Reason for edit: No reason given.
chronamyd
Reg: 05-02-12
01-10-18 05:42 PM - Post#2720718
I will rebuild the 261 as it uses oil according to the fella I bought it from. The motor is from a 55 chev pickup and has solid lifters. I will rais comp. ratio if I have to replace pistons. I am more after fuel milage as long as the power doesn’t suffer too much. I want to put duel 2 brl Webber’s on a offenhouser man. I also have a set of headman headers. Then I want to put a t -5 from a S-10 along with S-10 4x4 rear end prob. 3:73 . What am I looking at to install the T-5 to the 261 with the 54 bell housing. Right now My gtoup and my wife and my self go to a lot of car shows in BC and western USA. We put on around 6000. Miles a year with my 64 Impala SS 409 Duel quad. I worked about 8 yrs doing a full restoration on it. Last winter 2016I replaced the M20 with a tremec tko 600 5speed Dwight
chronamyd
Reg: 05-02-12
01-10-18 05:44 PM - Post#2720720
I will rebuild the 261 as it uses oil according to the fella I bought it from. The motor is from a 55 chev pickup and has solid lifters. I will rais comp. ratio if I have to replace pistons. I am more after fuel milage as long as the power doesn’t suffer too much. I want to put duel 2 brl Webber’s 32-36 ‘s. on a offenhouser man. I also have a set of headman headers. Then I want to put a t -5 from a S-10 along with S-10 4x4 rear end prob. 3:73 . What am I looking at to install the T-5 to the 261 with the 54 bell housing. Right now My gtoup and my wife and my self go to a lot of car shows in BC and western USA. We put on around 6000. Miles a year with my 64 Impala SS 409 Duel quad. I worked about 8 yrs doing a full restoration on it. Last winter 2016I replaced the M20 with a tremec tko 600 5speed Dwight
chronamyd
Reg: 05-02-12
01-10-18 11:30 PM - Post#2720756
01-11-18 01:35 AM - Post#2720758
Adapter plates are available which will allow you to bolt the T-5 to your stock bellhousing. The advantage of this (instead of using a later bellhousing) is that you can keep your stock clutch linkage without having to do any modification on it.
http://www.hotrodworks.com/product/1940-1954-che vr...
Execution time: 0.243 seconds.   Total Queries: 18   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:52 PM
