Username Post: igintion switch        (Topic#338362)
chiefdlf
chiefdlf
Loc: wilkes barre pa
Reg: 10-06-10
08-16-16 03:43 PM - Post#2646078
its been a while since i have had an issue but here goes : purchased a 69 442 numbers match restored car...the first position on the ignition switch should bring on the gen (alt) light am i correct??? it does come on in the start cycle and then goes off but i also thought it came on the first position..?? Batt running down im thinking switch not hooked up correctly?
MikeB
MikeB
Loc: Plano, TX
Reg: 08-28-03
10-03-16 08:20 AM - Post#2654640
    In response to chiefdlf
Typically when the IGN switch is ON with the engine not running, the ALT lamp should light. That's because the lamp has battery voltage on one side and is grounded on the other -- through the white "field" wire connected to the alternator windings. But when the alternator is spinning, there's 13-14 volts on the windings, and on the white wire.
The above is applicable to 10SI and 12SI internally regulated alternators, but I'm not sure if it's the same for external regulation. Which do you have?
Edited by MikeB on 10-05-16 08:57 AM. Reason for edit: No reason given.
Execution time: 0.892 seconds.   Total Queries: 15   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:16 PM
