Username Post: 84 Chevy Caprice 305 overheatinv        (Topic#337260)
Grpbatman
Reg: 07-06-16
07-06-16 02:16 PM - Post#2638151
Running out of ideas. Car was fine until I move the hot cold to hot for defrost and stayed there cuz cable broke. Manually put it back closed and then it starts boiling in overflow. Changed water pump and thermostat and will boil over within a mile. I replaced radiator cap and within a mile the heater hose on the motor side burst. Any and all suggestions are appreciated. I am a retired disabled military veteran And this vehicle is my only way to n from the doctor's. Thank you and God bless.
bowtieollie
bowtieollie
Reg: 12-06-99
03-11-17 10:58 AM - Post#2680887
    In response to Grpbatman
Hi Batman,
Really sounds like your new thermostat is defective. I would remove it and replace with a Gates or Stant Super stat. 180 degrees.
Bowtieollie
Chevytalk.com Moderator
noisyboy11221
Reg: 05-29-18
05-29-18 08:32 AM - Post#2735239
i had that issue with my 84 k5 i replaced the thermostat and water pump and it still did it i them replaced the radiator and it quit...i had a clogged radiator...mabey it would do some good to check yours
lizbeth
lizbeth
Loc: Az,desert rat
Reg: 06-22-03
05-29-18 03:12 PM - Post#2735286
    In response to noisyboy11221
My 84 caprice heated up on climbing..Replaced therm,then W.P.,then clutch fan.No help..finally changed rad and all was fine..Hard to trouble shoot that kind of thing..Wayne
OLTYMERZ
Execution time: 0.783 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:51 AM
