Username Post: full size hubcaps won't stay on        (Topic#336674)
Bryans55
Reg: 01-18-16
06-14-16 03:13 PM - Post#2633948
56 Chev Hub caps wont stay on. Could it the the after market wheels?
cdmhenry
Loc: Minden, NV.
Reg: 09-14-00
06-14-16 08:40 PM - Post#2634010
    In response to Bryans55
Yes. Aftermarket or later wheels lack the "nubs" that help secure the wheel covers.
Every Government Interference In The Economy Consists Of Giving Unearned Benefit, Extorted By Force, To Some People At The Expense Of Others - Ayn Rand
Bryans55
Reg: 01-18-16
06-15-16 04:09 PM - Post#2634168
    In response to cdmhenry
Thank you, Bryan
06-15-16 06:18 PM - Post#2634196
Do the wheels have the nubs that hold the wheel covers on? If so, the wheel covers may be deformed at the nubs to cause them to come off. I have had good luck forming the edge of the cover out at the nubs so they stay on.
gotta56forme
gotta56forme
Reg: 09-19-03
06-15-16 06:27 PM - Post#2634201
    In response to acardon
Don't know if it's true for each year of tri-five Chevs, but supposedly the Canadian wheel covers used a different (i.e. better) method of creating tension & tooth to the wheel, besides the nubs - I don't remember the details.
I'm to understand the nubs also help from keeping the wheel cover to shift/slip/rotate on the rim which has caused some rubber valve stem shearing.
You might want to look into the Canadian wheelcovers, unless you have a really nice $et already.
Gotta56forme/Scott
bowtiefan
bowtiefan
Loc: Vacaville, CA
Reg: 02-19-04
06-15-16 07:22 PM - Post#2634213
    In response to gotta56forme
Metal valve stems will keep your hubcap from rotating, and maybe even help keep them on.
Ken
38 & 39 2dr sedan, 41 coupe, 54 convertible, 56 Nomad, 57 210 2dr sdn, 70 Camaro RS, Corvettes; 57, 61, 65 396 coupe, 67 427 convert, 69 & 72 T-top, 88 coupe,91 ZR-1, 07 Z06, 16 Z06, 07 Silverado, 09 BMW 135i vert.
http://www.picturetrail.com/ken58
Bryans55
Reg: 01-18-16
06-21-16 07:29 PM - Post#2635337
    In response to bowtiefan
They don't rotate anymore since I put on metal stems. I also reshaped the cover were they go over the nubs.Will see if that sovles the problem next time I drive it.
madasell
madasell
Loc: Great North-Wet, Orygun
Reg: 04-21-03
06-22-16 02:36 PM - Post#2635468
I lost a cap with the metal valve stem installed. They work great to keep the cap from rotating, but when the cap did come off, it broke off the metal valve stem. It's amazing how fast a tire can lose all it's air with a broken stem
I gave up and now use gray RTV at many spots around the wheel rim to secure my '57 spinner caps now. Haven't lost a cap since, going on 5 years now. I use a paint can lid removal tool to pry off my caps now.
Do these fins make my rear end look big?
nomads
Execution time: 0.231 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:18 AM
