Username Post: New harness ignition problems 58 belair        (Topic#336549)
uniballer63
Reg: 05-15-16
06-09-16 07:11 PM - Post#2633136
I installed a new under dash harness and engine compartment harness. Now the gen light stays on even with the key out. And it won't start. Not even a click. It ran before I wired it but had some hokey wiring any ideas
aawtech
Loc: Bellmawr, NJ
Reg: 09-11-06
06-10-16 05:46 AM - Post#2633183
    In response to uniballer63
Not really giving me enough info. What engine, trans, other options? Does it have an alternator or generator? What harnesses did you buy? Do you have the part numbers?
Donny
uniballer63
Reg: 05-15-16
06-10-16 07:06 AM - Post#2633198
    In response to aawtech
Sorry, the under dash is item number CF30105 and the engine harness is CF40122. It's a 58 belair with a 350 and auto Trans with a alternator.
aawtech
Loc: Bellmawr, NJ
Reg: 09-11-06
06-10-16 08:42 AM - Post#2633211
The front light? That one is a potential problem if you have an alternator as that is where the Alternator plugs in at. If you have not changed that, your issue could be there. The exciter circuit fort the alternator is also the bulb check on the light.
DB
Execution time: 0.201 seconds.   Total Queries: 15   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:10 AM
