Join the Community today
Username Post: Gas Smell        (Topic#335839)
butofl
Loc: Marietta, GA USA
Reg: 12-05-02
05-16-16 11:26 AM - Post#2628635
When starting my 1996 Monte Carlo LS with the 3.1 liter engine, I get a heavy gas smell coming from the top of the engine. I also notice what looks to be a small amount of gas on top of the engine. Any ideas on what could be leaking gasoline?
x inFEKTid x
x inFEKTid x
Loc: east side of atl
Reg: 04-14-08
05-16-16 01:43 PM - Post#2628663
    In response to butofl
if gas is ion the top of the engine, im sure you already know there is a leak somewhere.. se if you can find the' dirt " or fluid trail of where its coming from . it may be the fuel rail as i think the newer cars use them . it should be an all metal line coming off of the fire wall (possibly) but ends up splitting off into each cylinder or it may look like a log ,but one end has what looks like a bike tire valve on one side of it. thats where you check pressure at as a side note.
like i said im not too familiar with the newer engines. its worth a look though ..
Execution time: 0.189 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:51 AM
